| Joining a fiberglass cabin to a steel hull I have a 44' steel hull and would like to remove the steel cabin by cutting it off just above the deck and replacing with a newly built fiberglass cabin. I am looking for suggestions on how to join the fiberglass to the steel. Bolting? Joining the fiberglass to the steel? ........ Also are there any issues with this? Is this a bad idea having fiberlglass mated to steel? |
| If the structure is not compromised by this modification the big problem is the difference in expansion rates, but it is common enough . Weld a stainless riser in place use a polyurethane sealer (or other sealing gasket) in a layer at least 8mm thick and bolt through a cover plate then the FRP then the riser. Hope this helps
| Fiberglass over steel hull boat | Guest | Materials | 8 | 12-12-2007 09:00 AM |
| Joining a fiberglass cabin to steel hull | Tygafan | Boat Design | 5 | 11-15-2007 09:23 PM |
| Steel-made hull with fiberglass-made radius chine ? | xarax | Metal Boat Building | 48 | 07-23-2007 11:35 AM |
| Steel-made hull with fiberglass-made radius chine ? | xarax | Boat Design | 0 | 07-05-2007 01:43 PM |
| Kayak hull joining question | Thin water | Fiberglass and Composite Boat Building | 12 | 07-06-2006 11:43 AM |
