| an idea for a welding combo I got this idea when I saw an ad for an arc welder powered by a Perkins 40 hp diesel.You can see where I'm going cant you? Combine it say say the attached shown and I have a motor for my boat when I'm done and a portable welder for repairs. Im nowhere near this point yet and I know Id need a lot more in the way of equipment. I am curious though if I have got the right Idea for basic the requirements.
__________________ You eat life or life eats you. Last edited by lazerus : 11-04-2008 at 02:58 AM. Reason: grammar |
| And their hype Pricing $741.64 The Arc One I 200 STL is the most reliable, powerful, and economical portable inverter welder in its class. Weighing in at 17.5 lbs, this portable welder can deliver 200 amps at a 60% duty cycle, 160 amps full time for stick/180 amps full time (TIG). Able to use a 1/4 inch stick, this welder will surely cover your needs. Built with solid state circuitry, it generates much less heat for a longer duty cycle and increased productivity. The current output is a higher frequency leading to cleaner welds and less re-work. Backed by a 1 year warranty on the machine, ESA approved, you canít go wrong. This superior inverter welder is backed by a 1 year manufacturer's warranty against all defects resulting from materials or workmanship.
__________________ You eat life or life eats you. |
| this diesel welder? mig? tig dc stick? |
| balsa divinny combo | rturbett | Fiberglass and Composite Boat Building | 6 | 10-15-2008 06:33 AM |
| Looking for combo Cruise-Sleep-Ski boat | jessdewet | Powerboats | 16 | 06-05-2007 05:07 PM |
| Aluminium Welding | daedong | Metal Boat Building | 4 | 06-05-2006 05:16 PM |
| Welding Iron | Hammersmith | Metal Boat Building | 3 | 04-25-2005 01:43 PM |
| welding aluminium | captain butch | Boatbuilding | 9 | 12-31-2004 03:21 AM |
