Old 07-10-2009, 06:05 PM
gomoto69 gomoto69 is offline
Rep: 10 Posts: 3
hull extrusions necasary?
I'm starting to build an aluminum hull to be fitted with jet drive. I'm trying to decide whether or not to obtain the hull and gunwale extrusions that some boat manufacturers use, where the bottom and side sheets of metal join together. Is this a better way to build as upposed to just welding the sheets together? I plan on 3/16 bottom and 1/8 sides. thanks
Old 07-17-2009, 12:27 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,691
all depends upon the geometry, the access, the alloy grade and temper and the environment it is in...oh and your budget too!
standard aluminum extrusions ringoo83 Metal Boat Building 4 04-02-2009 03:14 AM
6005-T5 for marine extrusions grob Materials 9 01-23-2009 12:29 AM
Shape of extrusions Celine Boat Design 6 01-06-2006 06:42 AM
Aluminum Chine Extrusions afinney Metal Boat Building 13 02-06-2005 04:08 PM
Extrusions twisting/bending Rhino Thunderhead19 Software 1 09-15-2004 03:08 PM
