Old 01-22-2006, 02:21 PM
whalepass whalepass is offline
Rep: 10 Posts: 2
How to remove paint from the hull of a riveted aluminum boat?
We just got an older Starcraft riveted aluminum boat, and I would like to know the best, easiest, safest and fastest way to remove the hull paint. I am concerned that chemical removal may loosen the rivets. Any information would be greatly appreciated.
If there is no best, easiest, safest fastest way to remove the paint, then what cleaner is available that will take off saltwater scum? The boat is sound, no holes no loose rivets, no leaks, but it extremely stained from the water line down.
Pat
Old 04-24-2006, 06:40 AM
lonestarcruiser lonestarcruiser is offline
Rep: 10 Posts: 7
Hey, I have the same task to perform, also some fiberglass on the hull of my Lone Star 21' Cabin Cruiser...do you have any good solutions to either?
Old 04-24-2006, 08:38 AM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
whalepass-
Chemicals wont loosen the rivets if it was built correctly. If it does, than you have much bigger problems. Use a non-etching remover. Don't scrape either unless your going to repaint.
lonestarcruiser-
how far down do you want to take it? All the way, or just a few layers? I would probably just sand it.
Imagination is more important than knowledge.
-Einstein
Old 04-24-2006, 10:23 AM
Rep: 10 Posts: 7
Actually..Whalepass...I am going to polish the entire boat with MOTHER'S or a similar compound. I have used it in the past on aluminum pieces I have machined for my motorcycle and on some stainless parts and the final finish looks like CHROME...pretty amazing stuff I think. So, any abrasive would not be good on this particular hull.
Thanks for any advice..
Sam
Boat Floor Paint.. ahasiec Fiberglass and Composite Boat Building 2 01-05-2006 01:26 AM
Looking for hull design for aluminum boat Jklipper Metal Boat Building 3 04-03-2005 10:57 PM
Paint System For Epoxy Hull VIKING Boatbuilding 5 02-02-2005 04:02 AM
Aluminum V-Hull Power Boat bud1000 Boat Design 7 09-03-2004 01:01 AM
Is ther an easy way to remove stringers? Saltyredfisher Boatbuilding 8 05-25-2004 09:13 PM
