Old 04-26-2005, 02:30 PM
AliBaba AliBaba is offline
Rep: 10 Posts: 3
how to make Keel in aluminum
Guys, I need some help in creating the keels in the base of a 18 foot jon boat. I would like to create 3 one inch deep keels. I am working with .125 aluminum (5086-H116). I would also like to put one keel on each sidewall aswell. I have looked and asked around but have been unable to figure out how to do this task. Any help would be great.
Thanks
AliBaba.
Old 04-26-2005, 08:28 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
A long bed, light duty, press. You can look for a metal fabracator shop and try to work out something. Depending on your standards, you could use "T" bar stock and just round the ends neatly and have both side flats for weld or rivit. It should be strong enough in the better grades. Or go with "U" or straight sided channel. Rivit center or weld the sides. Sides, only a "L" should do and with thought it would support any thing else mounted inside. Leery about "L"? Use the "T". There is always more than 1 answer to a problem.
Old 04-28-2005, 09:24 PM
AlaskaFisherman AlaskaFisherman is offline
Rep: 10 Posts: 76
No long bed presses around here. I would use "T" bars or the "L".
Cold Water[FONT[
Old 04-29-2005, 02:01 AM
Arrowmarine Arrowmarine is offline
Member
Rep: 10 Posts: 107
i would use 1-1/2" X 1-1/2" angle for the center keel and T bar for the sister keels and side "keels" I have used this configuration several times with no field failures.
Lifting Keel JHuberman Boat Design 19 06-26-2007 03:11 PM
Cheap And Simple Hi-Tech Keel? Wynand N Boat Design 9 05-24-2005 08:55 PM
Internal keel reinforcement fishboat Sailboats 11 10-10-2004 09:09 AM
Altering shoal draft keel? CaptK Boat Design 8 10-06-2003 10:54 AM
