| Our Fire Brigade is looking for plans to build a steel sectional barge approximately 30 feet long, 8 to12 feet wide, using 1/4" steel or 55 gallon polypropylene drums to sleep and fire small to med pyrotechnic displays involving small cakes and mortar racks to fire 6’ star shells Any assistance would be most welcome Many thanks in advance Chief Fire Officer Simon Osborne |
) and seeing as I am good mates with Kumeu Brigade I will draw you one for free, but only if you put your requirements , as I said into clear |
| Barge floating platform for pyrotechnic (fireworks) displays Many thanks in advance for your offer. Our Fire Brigade also provides volunteer Fireworks displays for the Community and in doing so is looking for plans to build a deck barge as a floating platform for pyrotechnic (fireworks) displays. It needs to be able to carry a maximum of 2 people and up to 1300lbs of cargo. We have access to a good ongoing supply of 200 Litre polypropylene drums, which would be used as modular (floatation) Pontoons We would like to install 8 x 200 Litre polyethylene drums, into a frame under the barge which would hold the pontoons under the barge. Length: 8 m Width: 3.6 m Construction: mild Steel tubing and angle Pontoon: 220 Litre Blue Mauser Heavy Duty Polypropylene drums, 580 mm D X 925 mm H No of Pontoons: 1 x Port Pontoon, 1 x Centre Pontoon, 1 x Starboard Pontoon (8 x 220 drum), Fixture of Drums: Each drum securely tied down with two straps Centre of Gravity: cargo would be no higher than 4 feet above the deck Details: We want to be able to trailer/truck this down the highway to the Harbour. Email me back if you require more info simon@fire-rescue.ac.nz |
I'm interested in building a barge similar to the one shown in this link's video: http://www.astillerogustavomarquez.com/video1.htm Since I cannot afford buying it new, I'll appreciate it if you can please let me know if you can provide the plans as I have a welding team that can help me with the construction but depending on that I provide the plans. I just need it for crossing a river with capacity for a truck but occasionally might need extra capacity (at least 25 ton capacity) for crossing a Caterpillar. Thank you. |
| Hello D'Artois, I'm interested in building a barge similar to the one shown in this link's video: http://www.astillerogustavomarquez.com/video1.htm Since I cannot afford buying it new, I'll appreciate it if you can please let me know if you can provide the plans as I have a welding team that can help me with the construction but depending on that I provide the plans. I just need it for crossing a river with capacity for a Nissan truck but occasionally might need extra capacity (at least 25 ton capacity) for crossing a friend's Caterpillar. Thank you. |
| barge plans I am in the planning stages for a barge to carry tropical wood also. I am just beginning to search for plans. Any assistance would be appreciated. |
| I think Mr. Vishnu Baiju would be the man for that job. |
| Barge capacity Quote:
Will this barge even float in 1.5 meters of water? I do not know the math formula for figuring out these things. Charles Pugh |
#25
| Bijit, can these pontoons be towed? They seem kind of square and top heavy. Can you send a somewhat bigger drawing. We would not but on more than 20 tons at most. Look forward to hear from you. Thorwald
__________________ ----------------------------------------- www.expeditionyacht.org The ultimate expedition yacht conversion |
#26
| Hi I have just joined Boatdesign and have read your comments, maybe you can help me. I want to designe a double hulled barge, length 8m, width needs to be what ever will keep the bage stable stable. The gap between the barges will be 2m and I will be mounting a 4m diameter water wheel inbetween the barge. The water wheel will br constucted using square tubing so it will not be that heavy, I will however have to take the effect of wind force into account. Regards Tony 4 Africa |
#27
| Work Barge Conversion We have a 40' 1968 River Queen twin engine steel hull houseboat we are converting to a work barge. We are on a fresh water lake in northeast Oklahoma. The purpose of the barge is to install a crane capable of lifting portions of our breakwater for steel repair and to install new encapsulated floatation. I was asked to do some research and learn what I could from anyone with past experience with such a project. My main concern is structurally where is the best location to mount a crane and what size would be recommended on a 40' barge? I appreciate any advice or experience you have with this. Thank you |
| Durable Steel Hulls | Wynand N | Metal Boat Building | 11 | 01-27-2009 06:19 PM |
| 300' x 80' x 18' Dumb Barge | sbdlm | Metal Boat Building | 3 | 06-16-2006 01:35 AM |
| Looking for the right path to design and build | ben_morel | Education | 44 | 11-24-2005 03:51 PM |
| 255' Three-Masted Steel Barkentine for sale | Yachting | Marketplace | 0 | 02-09-2005 09:35 PM |
| foam filler for steel barge | Sue Fox | Metal Boat Building | 5 | 11-29-2004 07:18 PM |
