Old 08-02-2009, 07:20 AM
MidMichigan MidMichigan is offline
Rep: 10 Posts: 3
Hot Rolled or Colled Roll Steel Frames
I am in the planning process of building a 30' steel tug. As I am preparing to purchase steel a question formed in my mind. Should the Frames, Longitudinals, Carlins, and other interior framing be made from cold rolled steel or hot rolled steel? These are 3/16" or 1/4" bar stock. I can't seem to find that answer. Maybe it doesn't matter and I am just over thinking it!
Thanks for any help,
Old 08-02-2009, 04:46 PM
tazmann tazmann is offline
Rep: 192 Posts: 217
Co;d roll is nice for machining, sharp corners, cost more, and will rust fast as soon as you clean the oil off. I think Hot roll would be a better choice.
Tom
Old 08-02-2009, 05:48 PM
wardd wardd is offline
Rep: 443 Posts: 925
hot rolled is more stable as it dosnt have the internal stresses that cold rolling imparts and is less heat sensitive ie welding and such
Old 08-02-2009, 07:01 PM
Rep: 10 Posts: 3
Thank you for your input. I was thinking hot rolled too. Seems like the radius corners would only be a plus on the longitudinals as the sheet is wrapped over it. Primer would flow into the joint easier too.
Rolled gunnel... Gaspergoo Boat Design 3 08-03-2007 10:29 AM
Bending wood over steel frames..? Omeron Sailboats 17 06-29-2007 05:36 AM
Steel frames & ply cladding anyone sandpiper Boat Design 42 08-16-2006 12:12 PM
Steel roll with Bi-axe jfblouin Materials 0 09-14-2005 06:10 PM
Force needed to roll or counter roll fer_mayrl Boat Design 1 02-13-2004 04:21 PM
