| home-made aluminum transom ? Just aquired a 16 foot orlando clipper. It is in good shape overall but kind of neglected cosmeticly. I have noticed that someone in its past has replaced the transom wood and appairently fiberglassed the wood just before they installed it as there is a pool of resin where it meets the hull on the inside. The edge of the pool is loose from the hull. There is a cap on top of the transom which I will try removing. I don't want this to be an area where water can lay in the delaminated area and work its evil over time. I just got a miller dynasty welder which welds aluminum well. Someone here mentioned they made an aluminum insert to go in there instead of wood. I was wondering if I could use an aluminum version of channel iron, maybe 6061 about 3/16 thick- make solid verticles and then cut and weld horizonals. Maybe a top and bottom horizonal not cut. Maybe weld in some 1/8 sheet in the inward facing side where the motor clamps go. What would be a reasonable approach ??????? I am guessing the structural purpose here is to spread out the stresses from the motor's thrust and vibration across the whole back of the boat. Ideas ? Tim in Orlando |
| Would be better if you could post a picture or sketch of what you're proposing. However, I wouldn't recommend using 6061 if you're welding it and the weld is below the waterline or subjected to spray etc. |
| Home made hydraulic tranny | stimulak | Boatbuilding | 20 | 12-08-2009 02:11 PM |
| home made pontoon | f4imatt | Boat Design | 11 | 08-31-2009 06:48 PM |
| I finally made it home! | Distans 52 | Open Discussion: All Things Boats & Boating | 21 | 01-08-2009 07:58 PM |
| Home made Hypalon tubes | Nojjan | Materials | 5 | 05-01-2008 01:14 AM |
| Home made raft | Matt Haines | Open Discussion: All Things Boats & Boating | 1 | 03-28-2007 04:15 PM |
