Old 04-11-2004, 04:19 PM
Oran Oran is offline
Rep: 10 Posts: 2
Help - Transom O Ring 274 Hamilton
I just spent All day today trying to fit a hamilton 274 jet to an alluminium hulled RIB. We got it in OK despite the manual's instructions. However getting the flange , o ring and jet to play ball has stumped us. We tried by hand, as per manual using vegetable oil as lube, then we used long stainless steel bolts and started tightening them down. It still did not do the job and in fact we snapped the bolts to remove them. Any body any experience with Hamilton's transom flange's and o ring seals.
Oran
Old 04-14-2004, 01:55 AM
bobber bobber is offline
Registered
Rep: 10 Posts: 69
Try contacting ocean dynamics, in st davids, Wales. They specialise in building custom aluminium RIBs for commercial uses, and utilise Jet drives in most of their boats. as far as i remember, they use hamilton drives. however it has been a few years since i have been up there,
OCEAN DYNAMICS
OCEAN BASE
CATHERINE STREET
ST. DAVID'S
PEMBROKESHIRE
SA62 6RJ U.K.
TEL: +44 (0)1437 721390 FAX: +44 (0)1437 720747
e-mail link to: info@ribworker.com
Old 04-16-2004, 01:25 AM
kapnD kapnD is offline
Rep: 19 Posts: 143
snapped bolts
Stainless bolts are notorious for galling when tightened without proper lubrication. A liberal application of anti-sieze to the bolt threads before assembly will work wonders. Chances are that you never even got the bolts tight, they just felt tight when they galled--and you were lucky they broke off, sawing them off is no fun. gool luck!
Old 06-01-2004, 11:21 AM
Tim_Hastie Tim_Hastie is offline
Rep: 14 Posts: 55
I have put many jets in boats. is it a new boat...? If not check that your transom is flush older boats can be nasty for that after you cut out the jet whole. make sure your transom is at the right angle 5 degree (if your block is 5 degree) have you had to cut any material off the intake block ? if so where. The aft portion of the block should not be touched. The aft edge of the jet block should be in line with your bottom corner of the transom. Is it single or twin ? If all these things are good then you should be ok. If these things are good and it still will not go in then call your rep. I deal with Jastrum Eng. in st.cathrines Ontario. Or just call hamilton.
Cheers
TIM
Transom Bracket on a 19ft boat CapeCodder Powerboats 6 12-07-2011 09:30 AM
Attaching stringers to transom? mikkyle Fiberglass and Composite Boat Building 3 12-13-2004 02:21 AM
transom composition question pogden Fiberglass and Composite Boat Building 18 10-04-2004 09:55 AM
Composite Question, filling transom holes foca Powerboats 5 07-09-2004 11:46 PM
Wiring Aluminum Boat Chester Electrical Systems 7 04-11-2004 04:09 PM
