Old 03-06-2007, 06:40 PM
BamaFishin BamaFishin is offline
Help Mounting This...
http://www.davisnet.com/productpics/big/01461.jpg.
Not sure if the link worked but I'm mounting some of these that I made myself on my 12' Jon Boat but I wanted to know what I needed to do to keep it from leaking water?Do I need to use some kind of gasket material and bolts with seals on them or something?If someone could kinda of explain to me what I needed to do I'd appreciate it.Any info would greatly be appreciated.
Thanks,
James
Old 03-07-2007, 04:37 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Seal the wood with resin. If you don't have that, paint or glue would be better than nothing. Use bolts with a big washer on the inside. Before assembling, put a ring of silicone caulking around each hole, inside and outside the hull so when the bolts are tightened the caulk oozes up against the bolts. Sam
Staggered? engine mounting... Verytricky Sterndrives 2 11-21-2006 01:00 AM
Outboard Mounting saildog789 Sailboats 0 06-25-2006 06:58 AM
Custom Engine mounting pizalm Boatbuilding 2 01-31-2005 08:43 PM
Best bolts for engine mounting Kyle Wooden Boat Building and Restoration 4 04-01-2004 11:08 PM
Soft mounting of outboards Palmer Boat Design 0 03-20-2004 02:32 PM
