Old 11-07-2009, 08:26 PM
Wemdoug Wemdoug is offline
Rep: 8 Posts: 22
Help me out with my frame
Hello pls i want to know the type op metal sections used in the construction of barges. I'd also love to know if the regular electrode arc welding can be used.
Thanks
wem doug
Old 11-08-2009, 09:39 AM
gonzo gonzo is online now
Rep: 1397 Posts: 7,215
Yes you can use regular arc welding. What do you mean by type of metal sections? Are you trying to design a barge yourself?
Old 12-17-2009, 02:04 PM
Rep: 8 Posts: 22
Thanks gonzo. Actually yes i am trying to design a barge by my self and by metal sections i mean
1). The type of material fo the frme.
2). Will it be I beams, u bars or angle iron.
3). The size of these metal sections
Old 12-18-2009, 01:27 AM
pdwiley pdwiley is offline
Rep: 419 Posts: 367
Honestly the best thing to do is buy a set of plans for a barge that's already been designed & built. That way you get all the steel dimensions as well as (hopefully) the quantities.
I would not use any structural steel section that can't be easily painted during building and inspected afterwards.
You don't state how big the barge is to be, either.
PDW
Old 12-19-2009, 01:26 AM
Rep: 8 Posts: 22
Thanks pdwiley it actually skiped my memory to state the dimenssion of the barge it will be 8m wide X 15m long X 1.8m high. All dimenssions are in meters. Thanks
Old 12-19-2009, 02:01 AM
mark775
There is wisdom here; "I would not use any structural steel section that can't be easily painted"
Windshield frame brokenrinker Boatbuilding 3 09-06-2007 03:20 PM
Frame bachainsaw32 Powerboats 2 07-20-2007 11:25 PM
Frame Mods... roeslerjd Sailboats 0 10-30-2006 08:31 AM
multihull frame nukem419 Boatbuilding 1 06-08-2006 03:06 AM
Attaching Flooring frame to Rib Frame. jeff goldberg Boat Design 0 05-24-2006 02:34 PM
