Old 07-22-2011, 02:32 PM
buckshot68 buckshot68 is offline
Rep: 10 Posts: 5
help building aluminum flat bottom
yes can anyone tell me where to some sheet aluminum 5086 20 ft x 8 ft building a flat bottom and can i leave the bottom smooth or better to add chines thanks
Old 08-05-2011, 02:17 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Aluminum Flat Bottom
Directional control with a flat bottomed skiff is poor unless you add some kind of strakes or a keel to the bottom. Keep in mind that the higher the speed you're looking at, the more of an impact small strakes will have. If this is a low speed craft, you may find you need a keel. There are many different approaches you can take.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 08-12-2011, 04:08 PM
Rep: 10 Posts: 5
thanks thunderhead
Old 08-13-2011, 11:25 AM
Rep: 10 Posts: 5
can anyone tell me where to find a 20x8 foot sheet of 5086 aluminum sheet
Old 08-27-2011, 09:09 AM
Chase_B Chase_B is offline
Rep: 76 Posts: 53
You best bet would be to contact a boat manufacture, they get material in rolls at different widths, but before you do that , you need to find a place that has a brake and shear large enough to bend and cut a piece of material the size your wanting to manipulate,
Old 08-27-2011, 01:41 PM
aprophet aprophet is offline
Rep: 10 Posts: 6
http://www.alcoa.com/global/en/produ...ry=5086&page=0
I would check in with these guys and see if there is a distributor near you good luck
Help building a 17' long x 50" bottom flat bottom aluminum boat Loewman Boat Design 22 11-21-2011 12:31 PM
Help building a wooden flat bottom! Wolfgang123 Wooden Boat Building and Restoration 29 04-02-2010 10:25 PM
flat bottom hulls Neal283 Boat Design 81 01-26-2010 02:29 AM
Flat bottom alluminum boat building ? spracky Boat Design 7 01-19-2010 03:37 PM
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 08:51 AM
