Old 07-10-2010, 07:17 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Heat insulation of a steel
container
Sorry slightly side tracked but I have a 20' container in 29 C or 90F 80% humid to insulate
What is the go to insulate against the steel from the inside and then cover it with plywood or something?
Just to make it liveable as a temp workshop. It willl have AC.
Thanks
PS it will be at a marina so this is boating related
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 07-10-2010, 07:50 AM
apex1
Nice comment, the last one.........
I would use simple, cheap, HD styrofoam or polystyrene. Glued to the container walls. If there are no windows (where you would need some frames) the simplest and cheapest way.
Then cover with Al sheets when for tough duties, or these wooden chips* sheets (painted) when not. Again glued on. (polysulphate in buckets for both cases)
*cannot remember the right term in any language at present, sorry.
I have done that for more than 25 years with no probs.
edited: OSB was the term I was missing:
http://osbguide.tecotested.com/
Regards
Richard
Old 07-10-2010, 11:33 AM
Rep: 1493 Posts: 7,447
I agree
Old 07-10-2010, 07:58 PM
thanks guys
Old 07-10-2010, 08:18 PM
Brian@BNE Brian@BNE is offline
Rep: 140 Posts: 222
I'd suggest a corrugated iron roof as well, leave a few inches air gap. If you can, have some overhang also.
Old 07-10-2010, 08:23 PM
apex1
We put three bricks of about one ft. height on top and span (spun?) a canvas over it. Cheapest aircondition one can have.
Old 07-11-2010, 03:49 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
.....yup, and add a small pump to create a drizzling flow of marina water over the container roof; evaporation cooling at its best..........
Old 08-12-2010, 03:01 AM
cor cor is offline
Rep: 85 Posts: 94
I have a 20' container that I have been using in the arctic for a workshop. With a small Toyostove heater it has kept me warm for years now.
I used 2" pink foam (insulating foam from a lumber yard) covered with 1/2" plywood. After standing the foam and ply against the wall I drilled holes through to the outside and used long carriage bolts with nuts to hold it all together. The ceiling was propped up in place first and them the walls done second, that way the ceiling is held up without putting any holes in the roof. If you are serious about temp control inside I recommend insulating the floor the same way.
Old 08-12-2010, 03:09 AM
pdwiley pdwiley is offline
Rep: 531 Posts: 489
Originally Posted by powerabout View Post
container
Thanks
If you haven't already got the container get a high cube one. The 9'6" height makes them a lot better for workshops.
I second the others' comments re insulation. If you want to hang tools etc on the walls then glue some 50x50 timber to the container walls first, fit the insulation between the studs and screw the ply to them. My old team used to build lab and workshop containers to go aboard ship and down to the Antarctic, this is basically how we did it.
PDW
Old 08-12-2010, 03:32 AM
I was thinking of welding angle iron or something to the inside to mount the internal plywood at the suitable distance off the interior to allow for the insulation and give me some hard (er) mounting points should i need them
Thanks for the 9'6" tip
Roof insulation Manie B Boatbuilding 27 04-14-2010 01:22 AM
Free of charge, Steel - polyurethane foam -Steel insulation sheets rossgiles Fiberglass and Composite Boat Building 0 03-18-2008 06:43 AM
insulation for sale AAllen Marketplace 1 01-10-2005 03:45 PM
Insulation Alex Hall Materials 4 12-04-2003 04:53 PM
insulation Materials 0 11-16-2002 03:24 PM
