Old 01-15-2011, 05:19 AM
42 below 42 below is offline
Rep: 10 Posts: 10
Hatches
Hi all,
Can I please get help with putting down aluminum hatches on a steel deck !
The boat is all painted. All ideas will be welcomed
Thanks
Old 01-15-2011, 06:06 AM
micspoko micspoko is offline
Rep: 86 Posts: 194
if you want a properly join aluminium hatch with steel deck you must used a triclads
http://www.triclad.com/
www.pppnavaldesign.com.pl
Old 01-15-2011, 06:21 AM
Rep: 1493 Posts: 7,447
It is relatively simple. All it takes is a neoprene gasket to prevent the metals from touching. Also, there is a grease that helps isolating too. Most hatch companies sell it.
Old 01-16-2011, 02:14 PM
Rep: 10 Posts: 10
Old 01-17-2011, 04:07 PM
Rep: 1729 Posts: 2,462
It's very common to have alloy and wooden hatches on a steel deck. The coaming is steel not Triclad. As Gonzo says the touching part is the gasket. At the hinge you can simply use grease or if you want a dry hinge bush it with one of the bearing plastics like HDPFE.
Mike Johns.
Hatches Fanie Open Discussion: All Things Boats & Boating 21 07-02-2008 08:02 PM
Escape hatches Manie B Boat Design 14 05-31-2008 02:02 PM
Sealing access hatches BurnabyRocket61 Materials 1 04-27-2008 12:54 AM
Making Hatches? hunter Fiberglass and Composite Boat Building 5 08-17-2006 06:39 AM
How to design hatches? forestjohnson Fiberglass and Composite Boat Building 7 02-25-2006 03:43 PM
