Old 09-12-2010, 03:29 PM
partgypsy partgypsy is offline
Rep: 10 Posts: 28
grinding stainless steel fittings
I am putting new stainless 1" dia tees on an older boat with 1" stanchions. Well, it seems that 1" has shrunk over the years and the holes in the tees are too small for the old 1" stanchions. I have tried grinding them, but nothing touches them with any efficiency. Machine shop quotes are way expensive. What is the best way to enlarge the holes in these fittings. I reckon I need to grind off about 1/32".
Lukey
http://www.lukeysboats.com
Old 09-12-2010, 03:45 PM
Rep: 1493 Posts: 7,447
If the pipe shrunk, which is hard to believe, how is it more than 1" now and the tees don't fit? What is that you are grinding, the stanchion? That will weaken them and make them unsafe.
Old 09-12-2010, 07:02 PM
Rep: 3125 Posts: 9,399
Not to mention ruin their passivity.
Old 09-12-2010, 08:14 PM
pdwiley pdwiley is offline
Rep: 531 Posts: 489
Which part of the tee is too small diameter? The short leg or the through leg?
Fastest way is to put them in a mill and run a multi-flute cutter into the hole. Grinding out the inside diameter of the hole(s) is a waste of time and slooooow. Also you'll never manage to keep the roundness. It'd be quicker to change the stanchions to suit the tees if you try that.
Be aware that there are pipe sizes & tube sizes. The 2 don't interchange worth a damn. You may have pipe tees and need tubing tees, or vice versa. A good catalog here is your friend.
PDW
Old 09-13-2010, 12:26 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
Get a 6" dial caliper ($29.99 will do) and do some measurements. Get a list of common tubing and pipe sizes from the web. Get familiar with the technology, in other words. Stainless doesn't shrink from just sitting. Not as much as a thousandth.
You can't afford to modify the fittings so match new tubing to them and try to remember why you ended up with mismatched parts. It will come to you.
Old 09-13-2010, 02:45 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Partgypsy means that an inch is not what it used to be because his new tees do not have the proper inside diameter.
The problem is lack of quality control at the manufacturer's side. I've seen that many times already. In my country you must always buy bolts and nuts at the same time: if you buy a nut for a bolt you already have, it doesn't fit.
Especially with stainless steel there is a lot of tool wear, so you need to check tolerances frequently and replace a tool in time. Small Chinese manufacturers simply keep using a tool until it breaks.
Others think 1" is the same as 25 mm.....
Old 09-13-2010, 04:56 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
"Others think 1' is the same as 25 mm....."
...think you nailed it there CDK
Old 09-13-2010, 04:58 AM
mark775
"I reckon I need to grind off about 1/32"." - I reckon the number is 1/16".
Okay, I believe that you actually bought fittings for 7/8".
Old 02-20-2011, 05:05 PM
Rep: 10 Posts: 28
no humour zone?
Interesting assortment of answers. Thanks
I was trying to suggest in a light-hearted way that it seems that many items now are built with sloppy tolerances and lighter materials than in the past.
I bought a decent grinding burr and used a tapered plug as a guide. Deed is done.
Lukey
Stainless Steel Railing dannie_ga Fiberglass and Composite Boat Building 4 01-17-2008 11:11 PM
wanted: a source for 1.25" stainless rail fittings pabble Materials 0 07-19-2007 04:53 PM
Protecting Aluminium from S/Steel fittings MMNet SEA Materials 6 07-11-2007 06:22 AM
Stainless Steel Question dreamer Materials 3 05-04-2005 02:25 AM
Stainless Steel hull? trouty Boat Design 3 11-18-2002 02:57 AM
