Old 02-04-2009, 05:30 AM
dick dick is offline
Rep: 10 Posts: 12
galvanised parts on steel hull
Is it ok to use a galvanised pipe as a radio and radar mast bolted to a steel flybriddge on a steel boat same goes with a fully galvanised davit crane will they become sacrificial zinc for the rest of the boat?
If so maybe insulation will isolate and protect them.
Old 02-06-2009, 12:25 AM
Member
Rep: -33 Posts: 951
No problem at all. I've used welded on Galv for lifelines, handrails and used pre galv sheets for my decks , cabin wheelhouse, and cockpit , no problem in 25 years. Wash it with TSP,then water, then vinegar, then water , and let it dry before painting.
Brent
Old 02-06-2009, 01:12 AM
Rep: 10 Posts: 12
Thanks for the help what is TSP?
Old 02-08-2009, 08:25 AM
tazmann tazmann is offline
Rep: 192 Posts: 217
TSP Trisodium Phosphate All-purpose heavy duty cleaner.
Old 02-08-2009, 07:18 PM
Member
Rep: -33 Posts: 951
Be wary of Galvanized cleats . They are almost all cast iron, brittle as glass. I one broke all the welded on galvanised cleats off a boat ,with a single swing of a claw hammer for each one, very dangerous if they break under load.
Brent
Repairing a steel hull Jason Crum Open Discussion: All Things Boats & Boating 11 04-21-2009 11:56 PM
Steel hull wooden everything else? treeclimber@xtr Metal Boat Building 48 01-08-2009 12:10 AM
Plating over a steel hull ljw Metal Boat Building 10 06-20-2008 08:03 PM
steel hull vs other materials ajflick Boat Design 17 09-23-2006 02:25 PM
galvanised or s.s Lunde Sailboats 12 02-28-2006 04:12 PM
