| Galvanic corrosion protection Hello there Is there any basic rules on the galvanic corrosion protection of an aluminium hull. I'm thinking sizes/quantities of zinz bars vs. hull size. The material is EN AW-5083 Thanks in advance! Uffe "Ufling" Last edited by Ufling : 01-18-2010 at 05:49 PM. Reason: material added |
| In the galvanic series, zinc and aluminium are too close to provide protection. Only magnesium electrodes would be marginally effective. An aluminium hull alone will show very little galvanic corrosion unless there are stainless steel parts present.
| Outboard motors use zincs!! Whats in the boat --if its just a rowing boat then youlle have no trouble. |
| Hi It's 6,6meter, to be fitted with a outboard, see pictures here http://picasaweb.google.com/TeamUfling/AluAngler6605# I'll use A4 stainless bolts in the boat where rivets can't be used. The outboard is mounted with Stainless bolts. I have some grease specially made for Aluminium/Stainless connections. @ CDK, if I use magnesium won't that protect the zinc on the outboard? Thanks Uffe "Ufling"
__________________ http://teamufling.blogspot.com |
| Outboard motors use magnesium anodes in fresh water, so do outdrives. The term "zinc" is a generic name only. Some manufacturers use aluminum anodes too. Also, it depends on the aluminum alloy your hull is made of.
__________________ Gonzo |
They made wooden outboards in the war, didnt know that did you? |
| Trojan war? Anodes need to be appropiate for the metals they are protecting. The location is also important.
| Nope 2nd world war wooden engines, for limited use to escape the vicinity of a sinking aircraft. |
| Interesting discussion (CDK and Frosty) but it dosen't answer my question.. @ gonzo, if you have seen the pictures of the boat, would it make reason to place only one magnesiun bar below the waterling on the transom? Thanks Uffe "Ufling"
| Normally zinc in salt water, magnesium in fresh. |
Is that an option people? |
| Ufling, if you want longevity using stainless parts in wet areas must be avoided at all cost. There are aluminium bolts and nuts. Above waterline, isolate stainless parts by using nylon washers. If you feel the need for some extra precaution, attach two 4" magnesium electrodes about midships, one on each side and check how they survived at the end of the season. If they have dissolved more than 50%, use larger ones the next time. As Gonzo wrote, what you call zinc on the outboard may be something else, so the magnesium electrodes may not provide protection there. There is also an electrical solution to prevent corrosion. Google for "Mercathode".
| Impressed current cathodic protection can provide better performance, longer anode life and anti-fouling protection. |
| Thanks! I appreciate you guys taking the time to help. The boat will only be in the water when i fish, otherwice on the trailer. Mostly I fish in salt water, but somtimes also in fresh water. I think I'll look in to the impressed current cathodic protection.
| Corrosion | BertKu | Boat Design | 0 | 11-06-2009 01:17 AM |
| corrosion, bolts etc | bob the builder | Boatbuilding | 14 | 10-20-2009 07:29 AM |
| AACK! Galvanic Corrosion! | flydog | Boat Design | 10 | 07-03-2007 12:59 AM |
| Galvanic isolator | drs3317 | Electrical Systems | 35 | 06-19-2006 09:33 PM |
| Carbon and corrosion | Ssharpsjc | Materials | 5 | 07-08-2003 09:24 AM |
