Old 04-06-2005, 03:03 PM
Luc N Luc N is offline
Rep: 10 Posts: 3
Full size patterns or 'lofting' for steel boat?
I am considering building a steel displacement motorboat.
The 'Mackerel 29' pleasure trawler version from www.bodenboatplans.com looks very interesting to me. I am a welder/metalworker and can work from a decent drawing but this boat needs to be 'lofted', does not have full size patterns. I have never built a boat before and I am somewhat afraid of this 'lofting' thing. I'm not a rich man and the possibility of expensive mistakes is definitely there!
Boden says on their website : 'a simplified table of offsets such that the only full size drawing or lofting that is required is for the transverse sections and stem profile'.
Is it that simple?
I can't find a similar design (under 30 feet), with (or without) full size patterns, anywhere.
This is an economical displacement boat, fairly heavy, and an all-steel(!) vessel.
Some advice would be welcome.
Thank you.
Old 04-07-2005, 02:32 AM
SplineWeights SplineWeights is offline
Rep: 12 Posts: 40
Don't be afraid of lofting... It is not that hard to do at all. Recommend reading a book on lofting. It is really nothing more than placing dots out in reference to a line and then connecting the dots by use of splines and spline weights inoreder to get a fair line,
Hope this helps
Old 04-08-2005, 06:58 AM
yago's Avatar
yago yago is offline
__
Rep: 17 Posts: 118
[quote=Luc N]Boden says on their website : 'a simplified table of offsets such that the only full size drawing or lofting that is required is for the transverse sections and stem profile'.
Is it that simple?
QUOTE]
Very simple... it just means that you have to draw the frames full size on some steel or plywood plate.
"Lofting" as it in traditional and round chine construction, often wood, means that you have to draw the entire boat with waterlines, buttock and diagonals first at size 1:1 so that then from THERE you will take the measurements for the frames... that indeed is work intensive. It's also a pleasure though.. lots of sweet curves, drawn with long flexible battens until the artists eye is pleased
In your case, it's the frames and their spacing that defines the form, so there is no "full" lofting required because the dimensions are supposed to be in the table of offsets (a grid that gives you the distances of points on your frames to the vertical centerline and the waterline).
if the boat is hardchine, that is VERY simple, you only need the top (sheerline), each chine-corner and the bottom on the centerline so usually you will have just 3 or 4 points per frame that you then line up with a straight rule.
Don't be afraid, we are with you - just go and do it!!!
Gerd
__________
www.yago-project.com
Old 04-08-2005, 05:49 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
There are some great books dedicate to this subject. Ship and aircraft lofting and plate development might be useful to you. www.metalboatkits.com has some good options for you. They require no lofting at all, even though you supply the materials.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 04-18-2005, 03:27 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
Rather loft...
Wynand
A scatterling of Africa
Old 05-10-2005, 01:49 PM
ARGO ARGO is offline
Rep: 10 Posts: 15
I loft out my frames on the computer and get them water cut. It saves my back and knees.
Jason
Old 05-11-2005, 06:29 AM
Rep: 700 Posts: 3,207
"loft out my frames on the computer and get them water cut. It saves my back and knees.
Jason
If the designer can provide a good set of plans many times having a steel supplier do all the cutting , costs no more than doing it yourself.
Their sheets are very large , and the computer places all the cuts very efficently , and they can recycle any scrap .Accurate too!
Might be worth a look.
FAST FRED
Old 05-11-2005, 11:27 AM
hoagey hoagey is offline
Rep: 10 Posts: 14
I am going to purchase plans for a small aluminum boat and try my hand at building. The CNC files are not available, but the designer has said I may develop the files if I want to. I think it would be exciting and fun to learn how this is done.
My question is how I go about transfering the the plans to CNC files.
Any help would be appreciated.
Thanks, Hoagey
Old 05-11-2005, 12:55 PM
Rep: 10 Posts: 15
It just so happens that this is part of what i do. Send me a line
Jason
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
World's fastest flat's boat Powerboats 5 01-22-2006 12:17 PM
geometry of sailing Sailboats 8 10-12-2002 11:58 AM
Full boat plans maksic Powerboats 0 09-18-2002 07:25 AM
full bench boat seats bobboudignon Materials 2 12-01-2001 11:59 PM
