Old 10-16-2005, 03:26 PM
EASI54 EASI54 is offline
Rep: 10 Posts: 18
French bilge designs
Hello everyone!
I have a french built sailboat and have no other information to offer other than it is an alu hull. While cleaning out the bilge compartments I realized that THERE must be a design for water to flow from baffel/compartment to another and would like to have a better understanding of it's design. Is there anyone out there that knows about the "french drain" system or is it all the same for other boats as well, and more importantly, HOW it is supposed to work?
Thanks
Jean
Old 12-05-2005, 01:56 PM
chandler chandler is offline
Rep: 16 Posts: 378
Here in Maine a "french drain" is a hole dug in the ground filled with pea stone to dump basement sump water into because the builder or excavator was too cheap to run the drain to daylight.
In your case they are probably limber holes to allow bilge water to flow to the low point of the bilge to be pumped out.
bilge keels roxanne parola Sailboats 21 03-10-2006 10:35 PM
Sharing Kayak Designs? arduk Software 2 10-10-2005 03:30 PM
search an Internship for a french student Thibaud Services & Employment 0 10-07-2005 02:49 AM
Worlds Most Radical Boat Designs foxxaero Open Discussion: All Things Boats & Boating 0 08-15-2004 10:10 AM
Water in bilge liloldham Powerboats 8 07-23-2004 08:37 AM
