Old 07-26-2007, 09:24 PM
Rep: 209 Posts: 829
It is still a frame
Originally Posted by StianM View Post
I think frameless could be developed creativly. Waterpipes and fuelpipes and others not transfering media with to big temerature diference from the hull could serve as frame, so could a deck, fuel tanks, water tanks and engines bolted directly to the hull could serve as a frame. The hull's construction would determine stiffnes, deck rails.
Try to make eatch component a structual part.
If you don't nead a class to ishue a certificate you can do quite crazy things.
Annyway there is ways to save weight on the frames and it won't steal mutch space.
WHo said you need a complicate & huge frame. I can design a ship with a double hull, a floor, and a deck. That is the frame.
Old 07-26-2007, 09:29 PM
waikikin waikikin is offline
Rep: 157 Posts: 536
Jehardiman, great post representing the material efficiencies of using framing to steel.
Xarax, if you want a nice little boat, the Van DE Stadt 34 is still a pretty & valid design & formed up as frameless then frames inserted to accept bulkheads for a standard & functional fitout, the keel is supported by webs welded to floors that the tops of are level to support the cabin sole, chainplates attach to deep hanging knees possitioned for the purpose & help frame the settee backs, the decks use curved angle beams that headlining material easily attaches to. Very economically constructed of 4mm plate to hull & 3mm to deck in steel or 6mm & 4mm in alu & is a great start to getting a nice yacht of reasonable performance. Regards from Jeff.
Old 07-26-2007, 09:35 PM
Rep: 209 Posts: 829
I repeat - Frame does not take up space if done right
A boat needs bulkheads, compartments, these are frame.
fuel tanks, water tanks can be and should be part of frame.
Floor and its frames, creates bilge separation between bottom of floor .
Deck is ceiling and upper frame structure.
If you dont have a frame where are you going to attach engines.
Old 07-31-2007, 03:04 AM
StianM's Avatar
StianM StianM is offline
Rep: 114 Posts: 558
It could be a sailboat and then you don't nead engine.
If a outboard then it's not inside the boat annyway.
If a inboard it's normaly attached to the engine grider.
There is also limited how manny bulkheads you want to have and also how manny compartments. If the deck surface is big enough you will nead frames to hold it up so it wont bend when people walk on it.
If weight is a ishue you would like to keep enginegriders to a minimum.
Old 02-06-2008, 12:58 AM
Rep: 99 Posts: 491
Decks , chines, built in tank tops, keel and skeg structures al consitute fully welded longitudinal bulkheads. All parts of a sailboat hull are curves of one form or another. The ends of an origami hull are cones with the apex of the cone being the start of the chine. Between these are portions of a cylindre. Calculations for transverse frames are often made on the naive assumption that we are dealing with flat surfaces. Longitudinal stringers are far more effective structuraly on hard chine hulls than transverse frames, as any pressure on a longitudinal, along a curve, would put a compression load on a longitudinal , but siimply put a bending load on a transverse frame. It is easier to bend a piece of material than it is to compress it on end , especially if it is welded to the plate.
The biggest frameless origami boat I ever built was a 47 footer , which completed a circumnavigation and is now cruising portugal. A friend built an origami 60 footer which is still cruising, after 30 years.
Several friends have 55 footers which have cruised the central Pacific and the Northern BC coast in all weathers, year round. None have transverse framing.
Brent Swain.
Durable Steel Hulls Wynand N Metal Boat Building 11 01-27-2009 07:19 PM
Pros and Cons of Steel/Aluminum/Aluminium Allow hulls GumbyTheBorg Metal Boat Building 23 10-29-2007 06:24 PM
Through hulls in steel boats tpierce Metal Boat Building 10 04-15-2006 05:40 PM
Overuse of cathodic protection on aluminum or steel hulls Thunderhead19 Boat Design 6 02-28-2005 07:20 AM
No Limit reached limit Dutch Peter Boat Design 16 09-09-2004 08:20 AM
