Old 08-19-2010, 07:08 PM
Robbo Robbo is offline
Rep: 1 Posts: 25
Originally Posted by alidesigner View Post
I was assuming that you would coat the bottom and fit the deck later so condensation would form on the under side of the deck and drop onto the foam. Might not be such a big deal though.
Maybe the answer can be found at www.sprayfoam.com
thanks Steve, Ive registered on there to ask if it will attack Ally, as it doesnt seem to say specifically.
As you say, spray onto bottom plating and cover up later.
Condensation-in theory if its sealed and its closed up on a non humid day or drained, there shouldnt be any, once its gone from the trapped air?
Roof insulation Manie B Boatbuilding 27 04-14-2010 01:22 AM
Free of charge, Steel - polyurethane foam -Steel insulation sheets rossgiles Fiberglass and Composite Boat Building 0 03-18-2008 06:43 AM
Foam for Insulation, not structure pairomedicsfish Materials 5 07-06-2006 08:28 AM
Insulation Alex Hall Materials 4 12-04-2003 04:53 PM
insulation Materials 0 11-16-2002 03:24 PM
