Old 02-05-2005, 11:31 AM
kdolan kdolan is offline
Rep: 10 Posts: 3
Foam flotation for aluminum boat
I have my 16ft boat down to the hull and want to pour some type of flotation foaminto it to deaden sound and obviously give me some flotation. Anyone have suggestions about what to ues.
Kevin
Old 02-05-2005, 05:59 PM
Arrowmarine Arrowmarine is offline
Member
Rep: 10 Posts: 107
We use a two part pourable that works pretty good. Unsure of any info right now, put i am going back to the shop later this evening and i'll get all the info from the lable.
Joey
Old 02-05-2005, 06:04 PM
Richard Petersen
There are 2 ways to put foam flotation in the boat. I am not being a smart as_. Right and wrong places. Copy from a new boat that has VERY same layout as yours.--------- If at all possible. Keep all the foam block or spray in place in the TOP HALF of hull. Correction, Keep it all in the top half. NOTHING in the bottom 1/2. Use ONLY marine foam. OIL, GAS OR SUNLIGHT--- WILL NOT attack it.---------Home Depot types will dissolve.
Old 02-05-2005, 08:06 PM
Rep: 10 Posts: 3
Thanks for the advice. Will have to decide what to use and your straightforward advice as to sing home depot has me re-thinking.
Thanks,
Kevin
Old 02-06-2005, 03:18 PM
Bobber1 Bobber1 is offline
Rep: 10 Posts: 5
Hey I know a scottish guy who is rebuilding a boat....hey it's you.
Go to Crestliners sight and you will see them adding the foam. I have seen foam at the back and foam at the front.Mine is at the nose and the two upper back corners (3ft x 1ft).
Have fun.
Bobber
Old 02-06-2005, 03:32 PM
Rep: 10 Posts: 3
Heh Bobber
Will check out the crestliner site. Will probably go with the two part foam and will check around for pricing. Think I only need the small container as the back of my boat still has foam and it seems ok, it is the front that needs it and the centre.
Thanks,
Kevin
Old 02-06-2005, 07:46 PM
Rep: 10 Posts: 5
Try this link and hit the factory tour. They put their foam throughout, and put foam seats over the ribs to allow water to drain down.
http://www.boattest.com/general-info.aspx?ID=305
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Roll Instability on small outboard boat? RThompson Powerboats 14 06-09-2006 02:08 AM
Incredible "Secrets of Yacht Design" website located... pkoken Sailboats 579 10-09-2005 08:33 PM
Foam/Plywood boat plug construction ?s cla17 Boatbuilding 22 05-21-2005 03:44 AM
Concept Boat Design Contest Tad Boat Design 16 09-17-2004 11:13 AM
