Old 08-24-2004, 08:25 PM
Sue Fox Sue Fox is offline
foam filler for steel barge
I am in the marine construction business and have barges that we are constantly having to pump. My question is, has anyone heard of filling the hull of the barge with foam in order to seal it and keep it floating?
Any help would be greatly appreciated.
Old 08-25-2004, 04:50 AM
Rep: 66 Posts: 640
For the life time of a steel boat, filling it with foam is a bad idea.
Repair the leaks and your alright. I'm pretty sure that's also a lot cheaper!
Old 08-26-2004, 05:26 PM
Sandy McKerrow Sandy McKerrow is offline
Rep: 10 Posts: 5
I agree - cure the leak, it will be cheaper in the long run. If you do need to make structural repairs at a later date, after foaming a space, consider the time and effort, i.e. cost required to remove the foam.
Old 09-03-2004, 06:44 PM
diver1382
my advice would be to tell the company owner to not mess with the foam and buy new barges I would also tell him to give your husband a raise
Old 09-03-2004, 07:47 PM
Rep: 1623 Posts: 2,343
Very bad idea
You just end up digging the foam out again so you can weld it later on.
Sand blast the inside, repair the thin /holed plating , paint with zinc rich primer then 2 coats of epoxy.
Simple.................
Mike Johns.
Old 11-29-2004, 08:18 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
leaking barges
I guess that your problem consists of barges that are brought for repair and that have to wait for their turn to be docked. If you want to keep them from sinking put some collapsible rubber tanks in them. You might find in army stores usable stock. It depend of course how big they are. Filling it up with foam is as Dutch Peter says a very bad idea and after all - when the barge is going to be repaired you are still left with a mess of foam material. Second to that is expensive and
the result might be negligible.
Put your specific problem here, with the proper dimension of the barges and you might find an answer, for free....
Airex and any foam based hull materials tdamico Boat Design 21 03-04-2009 08:26 PM
Pourable foam, need advice BustedKnuckle Materials 6 07-10-2006 09:19 PM
Filler Foam Fat Sam Fiberglass and Composite Boat Building 4 04-27-2005 02:56 PM
Foam Block To Bass Boat... can this be done? Curious Fiberglass and Composite Boat Building 10 12-11-2004 07:21 PM
Foam and filler JJ£ Boatbuilding 1 10-08-2004 03:25 PM
