Old 10-30-2006, 06:01 PM
Bob boat bldr Bob boat bldr is offline
First time alum boat builder with lots of questions.
Hello, I am in the process of building a 23' aluminum outboard powered boat. All 5086 with some 6061 extrustions. 1/4" bottom and transom, 3/16 sides and decks and .160 pilot house. It has four longitudinals that run from the transom to the collision bulkhead and six transverse frames. two of which are watertight bulkheads. Everything outboard of the longitudinals that are closest to centerline is watertight. I want to cut some holes in the deck and fill these compartments with pourable polyurethane foam. I was wondering if any one knew of a good way to re-seal these holes? I was thinking of gluing down some oversized pieces of plate with 5200, but I think it would look lousy. Any suggestions?
Second, I am going to leave the hull unpainted. there are some areas on the hull that I had to use the grinder on due to mistakes when welding. Is there any way to get these spots back to a finish that will match the mill finish on the rest of the boat, or will it always look bad?
Third, every place that I welded the frames and the decks to the hull plate it is making visible lines on the outside of the hull. Are there any tricks to eliminate or minimize this in the future?
If any one has any suggestions I would greatly appreciate it.
Thank You,
Bob
Old 10-31-2006, 09:28 AM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
You could use neoprene gaskets under the plates to seal the holes.
TGoz
Old 11-05-2006, 03:28 PM
sal's Dad sal's Dad is offline
Atkin/Bolger fan
Rep: 80 Posts: 109
Time. In a few years, the surface will develop an even patina. You will still see the areas that were ground, if you look for them, but they will be far less eye-catching.
Grind down the raised lines. ( This, of course, brings you back to the previous problem
Old 11-09-2006, 09:24 PM
SolomonGrundy's Avatar
SolomonGrundy SolomonGrundy is offline
I'm not crazy...
Rep: 51 Posts: 166
heat lines
I allways just leave them. If you weren't careful and had some burn-through then that's a different matter. Since it is to remain unpainted, any grinding or attempt to buff it out will just make it look worse. If you really want to get rid of those slightly elevated lines on the opposite side of the sheet from the weld then try a power planer set as shallow as possible and make a few passes on them.
Old 11-09-2006, 09:40 PM
Rep: 527 Posts: 792
It is possible to return a brushed finish to aluminum after grinding or to remove scratches or other blemishes. With fine enough abrasive on the final pass, this can approximate the original mill finish. It takes special tools and a fair amount of skill and time. Whether or not it's worth this effort and treasure is purely a matter of preference. I would say "no" but you might say otherwise.
Anyway, here's the tool:
http://www.dynabrade.com/regions/1/i...php?item=13400
I think they will set you back about $1200 for the model most suited to the size of your project, and like any power finishing tool, there is a learning curve. I've got a mini one and with some practice, you can get a real nice straight line mill type finish on any metal.
Jimbo
Old 11-14-2006, 10:28 AM
alidesigner alidesigner is offline
Rep: 93 Posts: 170
Weld Penetration marks
Not much you can do about the ones that are there but to prevent more look into your shielding gas. If you are using argon talk to your gas supplier about an argon/helium mix. In Aus it was known as 81T and its now called Alushield Heavy. A better gas will allow you to use lower settings resulting in less heat. If this is a problem with the hull it will be much worse on the thinner deck house. Ali welding is different to steel welding. Because ali disipates heat so well you need to weld hotter so you must move faster. The other thing to consider is just tacking the plates together and then paying a qualified welder to weld it out. It costs more and is maybe less satifying than doing it yourself but that would be better than trying to fix buckles and burn through.
Deck cutouts
Weld some backing plate inside the hole in strips and sit an under sized cover on it. You can then weld or glue and fill for a flush finish.
Hope that helps.
First time boat-builder timplett Boatbuilding 46 08-18-2006 10:49 AM
Prop Material - Alum boat sal's Dad Metal Boat Building 9 07-13-2006 03:24 AM
Green horn needs lots of help Roger Brooks Fiberglass and Composite Boat Building 0 01-17-2006 07:52 PM
Looking For Small Fishing Boat Plans Alum. PDH Boat Design 3 03-21-2005 08:56 PM
First time boat builder Greg in Atlanta Wooden Boat Building and Restoration 14 11-29-2004 01:29 AM
