Old 01-16-2009, 03:18 PM
Conachair Conachair is offline
Rep: 10 Posts: 12
Fibreglass & resin as temp solution to pinhole
I have a patch of rust inside of the transom above the water line about 2' x 1'. There's a pinhole at the bottom of the rust patch aprox 1' above the waterline. I've ultrasounded the area and the thinnest areas seem to be about 1.5mm. Would covering this area with fibreglass matt and lots of resin work as a temp solution? I'm in Canaries and want to get across to Caribbean, would cut the piece out there and weld a new piece in. Seems to be sound steel around the patch, 3.8mm min and below the waterline seems sound. I've given the offending area a good going over with a hammer and apart from the pinhole the metal seems sound, just a bit on the thin side in places, already sanded back using anglegrinder with wire cupbrush with a coat of interprotect. Boat is 33' Ebbtide steel cutter. All thoughts welcom. Thanks. Paddy
Old 01-18-2009, 12:04 PM
tazmann tazmann is offline
Rep: 192 Posts: 217
repair
A fiberglass patch might work if it stays conected to the metal, but thats a big if. I think I would be inclined to sandwich the bad section with sheet metal trough bolted as a temperary fix.
Tom
Old 01-18-2009, 09:53 PM
welder/fitter welder/fitter is offline
Rep: 423 Posts: 407
Paddy,
What do you have/what is accessible to you in the way of tools & materials?
(welder?, drill?, silicone?, rubber padding(1/8" or? thick), JBWeld?, etc.)
What is location of problem area in regard to framing?
Mike
Old 01-19-2009, 06:35 AM
Rep: 10 Posts: 12
Tools available but getting some plate is proving difficult. Also would need to get lifted out to do any welding/painting which I don't really want to do where I am now. Here's the prob-
Interprotect (international 2 pack epoxy primer) seems well bonded.
Old 01-20-2009, 05:22 AM
Rep: 423 Posts: 407
Paddy,
If my eyes don't deceive me, you are talking about the area that the wire brush is pointed at? If I am correct & the metal surrounding the pinhole is sound, how about drilling the hole out a bit larger & use a nut & bolt through with ss & rubber washers? put the bolt through from the outside, sandwiching the rubber washer between a stainless washer & the hull. Tighten up the nut on the inside - use rubber & ss washers here also - and you're done. Crude, but effective. I'd tend to agree with Tom, regarding the risk of losing the epoxy. JBweld is a pretty good fix-all & can be found in most hardware stores, but, if it's a pinhole, I'd go with the nut & bolt, as the risk of losing the filler does exist.
Hope this helps!
Mike
Fibreglass modification & structual Integrity firefox7 Fiberglass and Composite Boat Building 3 03-14-2008 05:06 AM
temp buzzer saabster Propulsion 6 04-11-2007 10:04 AM
Problem - and solution? caribmon Boatbuilding 4 07-24-2006 12:21 PM
High-temp Fiberglass chris7891011 Fiberglass and Composite Boat Building 6 03-12-2006 08:57 PM
Webbing Solution aguest Boatbuilding 1 01-04-2004 11:00 PM
