Old 08-24-2010, 11:03 AM
KXBill KXBill is offline
Rep: 10 Posts: 4
Electrolysis damage repair on Aluminum
What would be the best methode to repair damage done by electrolysis on Aluminum. I'm thinking that a Aluminum loaded epoxy applied like "Bondo" over the damaged area would do the job "up town". Appreciate any ideas.
3's
KXBILL
Old 08-24-2010, 11:28 AM
apex1
As a temporary repair, why not. Sooner or later you will have to weld a patch in.
But imho you can leave the Al powder out when using epoxy putty.
You know you will have to etch the Al surface prior to apply the bondo!?
Regards
Richard
Old 08-24-2010, 02:43 PM
Rep: 10 Posts: 4
Didn't think of etching the damaged area since it's pitted but, the smooth area around it, yes, good idea.
Thanks.
KXBill
Old 08-24-2010, 03:16 PM
apex1
Thanks.
KXBill
You have to etch it all. The corroded area has already build up a oxide layer after some seconds.
Old 08-24-2010, 03:55 PM
wardd wardd is offline
Rep: 443 Posts: 925
check for inter granular corrosion
liberty ships were beautiful
Old 08-24-2010, 09:32 PM
Rep: 501 Posts: 1,767
Well not that easy. Is it structural, plate or is it skin? If not structural or thin skin, then Sand Aluminum to bare metal, etch, neutralize acid, then zinc chromate then liquid epoxy, then epoxy filler, sand then overall liquid epoxy, sand then paint. If structure weaken or skin then have to well new piece else epoxy wont really fix problem.
Old 08-24-2010, 11:48 PM
Rep: 10 Posts: 4
It's a pontoon boat. I'll ask the manufacture the thickness.
Later
KXBill
Tips on repair of this impact damage jayc Fiberglass and Composite Boat Building 8 07-27-2009 03:45 PM
Aluminum electrolysis prevention state of art Patrick BLOSSE Metal Boat Building 8 09-23-2008 06:52 AM
Aluminum electrolysis prevention state of art Patrick BLOSSE Electrical Systems 0 09-11-2008 02:38 PM
Should I repair my wood mast or use aluminum one? filiperosa Wooden Boat Building and Restoration 9 06-26-2008 07:36 PM
Please help me assess the damage and formulate a repair plan jksoft Wooden Boat Building and Restoration 4 11-14-2007 06:30 PM
