Old 09-09-2010, 03:03 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Too much praise SheetWise.
If I see the word dynamometer an electrical solution is the first that comes to my mind. But some say I was born with a voltmeter in my head....
A disc brake with an arm attached to the caliper and a sliding weight is a simple mechanical solution.
Or the clutch from an automotive A/C compressor and a variable power supply. Sorry, electrical again.
Old 09-09-2010, 07:31 AM
wardd wardd is offline
Rep: 443 Posts: 925
how about a hydraulic pump, valve, pressure gage and flow meter
somehow that seems like a solution to me
now for the math
liberty ships were beautiful
Old 09-09-2010, 10:11 AM
CDK's Avatar
CDK CDK is offline
retired engineer
now for the math
Plus an oil cooler.
Like an electrical system, that would need calibration. The brake with a long lever doesn't.
Old 09-09-2010, 04:07 PM
Rep: 443 Posts: 925
doesn't a true engineer complicate things?
Old 09-09-2010, 05:57 PM
Rep: 1729 Posts: 2,462
In engineering the one thing above all else that you hammer into every cadet, trainee and young employee is KISS
It's the most important engineering concept of all.
Mike Johns.
Old 09-09-2010, 07:37 PM
Rep: 443 Posts: 925
I used to work directly with engineers and they were always trying to impress each other, it got really weird at times with what they came up with
once i worked at boeing vertol in the wind tunnel making and preparing test models, it go so bad between the developmental mechanics and engineers that the head honcho got us together and said if the engineer couldn't tell us what he wanted in language we could understand then he had the wrong man on the job
Old 09-09-2010, 08:00 PM
pdwiley pdwiley is offline
Rep: 531 Posts: 489
Ditto software development. I used to have staff that never saw a simple and straightforward problem that they couldn't make complex & baroque. Then they'd (be encouraged to) move on....
PDW
Old 09-09-2010, 09:17 PM
SheetWise's Avatar
SheetWise SheetWise is offline
All Beach -- No Water.
Rep: 574 Posts: 274
PDW
When you learned on 8k RAM, that was never a problem
Time is Gods way to keep everything from happening at once.
