Old 10-08-2008, 10:14 AM
ACuttle's Avatar
ACuttle ACuttle is offline
Marine Design Engineer
Rep: 40 Posts: 85
Ignoring cost or surveying factors, if you wanted to chop a boat up then put it back together I'd have thought the best you could do is:
Work out the biggest possible units you could manage (with respect to structural elements). I'd have thought for a hull like that you'd want one big central section as wide as possible with two wing sections - though you'd have to be careful not to loose all your vertical structure (or replace it with something else). You'd have to look quiet carefully at the structure of the boat as it stand now before choosing the cutting lines.
Heightwise you might have a problem choosing where to split but you'd best go for somewhere you can easily access to re-weld when you come to put it back together.
Before cutting cross brace both sides of the area the cutting line would go through - this will help stopping any torsional forces built into the hull from twisting is out of shape.
Put on maker points at key hull areas including a fore to aft straight line of points. Also include marking points that should line up on cuts when you come to reassemble.
Cut with a stepped cut so that the parts meet back up when reassembling.
Ship and then reassamble, when rewelding cut back and replace with a new stepped section any severed internal structural components and replace them so that there isn't a single uniform welding line.
Well that you be my thoughts anyway.
Old 10-08-2008, 11:51 AM
eponodyne eponodyne is offline
Rep: 166 Posts: 327
Originally Posted by pathfinder_05 View Post
you help no-one!
Just because you didn't get the answers you were hoping to get--that doesn't mean no help was forthcoming. The overwhelming opinion of the community (some of whom have literally forgot more about boats than you will ever learn) is that your idea is bloody stupid. Instead of recognizing this as genuine help, you choose to get all in a huff.
So go take a **** in your hat. Then go **** straight off.
Old 10-08-2008, 02:36 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
If a boat was put together in sections, as a metal boat is, then I assumed it could be taken apart and rebuilt in sections again, just larger ones.
Never assume, that is the mother of all Fu*kups...
Small boats are not build in sections, but formed by hand from a - z piece by piece. Some plates are forced into place before welding. And welding put a lot of stress into plates and as another member tried to explained to you, the hull will twist out of shape when you try to cut it to pieces - I for one believe stiffener braces will be of little use.
To give you an idea of the amount of welding that goes into a hull - I'm building a 43ft radius chine now and the hull only has 355 linear meters of welding on the OUTSIDE alone. Double that for the inside as well. Then add the welding to the stringers, frames etc and add the deck.....
If you manage to cut that nice boat into chucks and achieved the impossible by getting it together again, please post a photo of the finished product - we need a few laughs around here I believe the end result will be disastrous.
No one here tried to piss you off, but your outrageous suggestion mystified our minds a little and perhaps we are still from the old school. But then again, try to read between lines and see the humor intended and lighten up.
Wynand
A scatterling of Africa
Old 10-08-2008, 03:18 PM
RHP's Avatar
RHP RHP is offline
Rep: 1073 Posts: 568
Life´s a box of chocolates and I would like to thank Pathfinder for cheering me up on what has been otherwise, a pretty shitty day.
Thanks mate and dont forget to take the glue.
Richard
Old 10-08-2008, 03:34 PM
Previous Member
Rep: 0 Posts: 0
Richard
hey Rich
do you ever sign RIP? )
Old 10-08-2008, 03:38 PM
Previous Member
Rep: 0 Posts: 0
Hi Guys,
Many thanks for the 'input' so far. A few thing I should have mentioned when I wrote the post was......
I have two months till departure.
I have no money.
Cars and boats are very expensive in Chile.
It is more economical to take everything with me than it is to sell everything and start again...... do you think I'm some frickin newbie to 'life'? I might be to boats but not to travelling and living in Chile you ******.
I asked for constructive comments not a giant piss take.
I can't sail over due to many circumstances.
Anyway, thanks for bugger all.
DB
WE WERE ATUALLY doing you one big favour, one day you will see thsi, good luch, , , oh not quite sure how the spar was going into container, chop it up too) nah seriously good luck mate, one day you will have money, then like me you can lose it again)
Old 10-08-2008, 03:42 PM
Member
Rep: -33 Posts: 951
I'm sure lots of cruisers would love to cruise to Chile from Spain just for the cruise if you give them lots of time to do it.
Brent
Old 10-08-2008, 03:46 PM
RHP's Avatar
RHP RHP is offline
Originally Posted by lazeyjack View Post
hey Rich
No.
Old 10-08-2008, 07:11 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Geeezzz, no wonder the guy has no money Put the thing in a container and ship it. You can always find someone else to blame if it gets out stuffed the other end. Worst case scenario you can have a big BBQ with the wood.
Regards
Fanie
Water ! Just gimme water !
  #25
Old 10-08-2008, 07:23 PM
Fanie's Avatar
Fanie
If you are so 'experienced' in life why ask anyone ? Mmmm. new to boats eh. Good luck, it's almost the same as driving your car, just a slight bit different.
Regards
Fanie
  #26
Old 10-09-2008, 02:59 PM
Rep: 700 Posts: 3,207
IF you live near a port , go and talk to some of the ship captains.
Yours would not be the first to be hauled aboard , out of port and splashed outside a harbor , for you to sail in.
NO money wont work , but little may.
FF
  #27
Old 10-09-2008, 04:22 PM
pathfinder_05 pathfinder_05 is offline
Rep: 4 Posts: 5
I surrender!!!!!!!!!!!!!
Ok, ok........ I'm calling a ceasefire. My hands are in the air, I'm stepping away from the cutting equipment!
I had a bad few days and some of the comments rubbed me the wrong way.
I'm glad to have caused some humour in here....
I'm sorry to have annoyed some folk .......
I still have my head up my arse!
I bid you all farewell.
  #28
Old 10-09-2008, 04:58 PM
Butch .H Butch .H is offline
Rep: 188 Posts: 631
Good Luck to you I hope you get your boat over.
If all else fails hit it with a hammer
  #29
Old 10-09-2008, 05:15 PM
Previous Member
Rep: 0 Posts: 0
dont give up!! for 5000 pounds I will cut it up very neatly for you, oh plus airfares)
  #30
Old 10-09-2008, 05:53 PM
Member
Rep: -33 Posts: 951
You could sell her there , and build a boat in Chile for less hassle and expense
Brent
Shipping a boat from overseas... (Shipping a wooden boat from Finland to Alaska) Spin_Drift Open Discussion: All Things Boats & Boating 27 03-12-2009 09:45 PM
Cutting through a steel hull for water in and outlets AWegener Metal Boat Building 30 02-14-2008 09:52 PM
Steel yacht construction SeaSpark Boat Design 41 02-12-2008 04:12 PM
Cutting 316 stainless steel... epoxyman Boat Design 9 01-07-2007 10:55 PM
Cad-Cam steel-cutting plan C.W. PAANS Boat Design 0 09-09-2001 10:32 AM
