  #31
Old 02-14-2008, 09:52 PM
Member
Rep: -33 Posts: 951
With a 4 ft piece of 2X4 , a piece of chain and a bit of imagination , it is easy to chain one end of the 2X4 to something , lean the first 1/4 of it's length across the back of a drill and lean on the other end while using a hole saw, giving you the pressure of a drill press, making the job much easier. A 5 gallon plastic bucket full of water with a tiny hole in one side of the bottom aimed at the hole you are trying to make will cool things down quite nicely as you drill .
Brent
Cement Lining for Steel Water Tanks jglassman Materials 9 12-24-2010 08:24 AM
coating under water steel gotwind? Metal Boat Building 2 03-27-2007 09:12 PM
Cutting 316 stainless steel... epoxyman Boat Design 9 01-07-2007 10:55 PM
planning on cutting a wooden hull along the centerline jedclampit Wooden Boat Building and Restoration 25 07-11-2006 10:28 PM
Cad-Cam steel-cutting plan C.W. PAANS Boat Design 0 09-09-2001 10:32 AM
