Old 09-20-2009, 11:30 AM
wardd wardd is offline
Rep: 443 Posts: 925
crazy idea
not knowing anything about building boats i'm permitted to come up with unusual ideas
in a cold molded boat instead of using wood, how would narrow thin strips of aluminum epoxied together then with wood or aluminum outer?
Old 09-20-2009, 05:52 PM
Rep: 2891 Posts: 8,796
The other way around makes sense, skins of sheet aluminum, glued to a core (foam or wood). In fact, you can buy panels made like this now.
Old 09-21-2009, 12:46 AM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1298 Posts: 1,991
Modern doors (for houses) are foam cored, aluminium plated with a veneer covering on both surfaces..
Old 09-21-2009, 01:53 AM
Rep: 443 Posts: 925
i was thinking of using the strips of aluminum as the veneer would never rot and may be stronger
Old 09-21-2009, 02:48 AM
TeddyDiver's Avatar
Gollywobbler
Pound/pound wood is stronger.. and rot resistance ain't an issue when properly done with epoxy.. but possible and in some places might have major advantage like in ice..
Old 09-21-2009, 03:02 AM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
Aluminium must be "clean" and "etched with fine grit" and even then if water gets in corrosion could be totally hidden until it falls apart because the alu became weak and corroded... nice try
My crew went to a lot of effort to prepare the forward beam on my build, several days of preparation just for that little area - and you are talking of a whole boat - - - Just build the boat of alloy - that material comes into its own around 40 to 45 ft LOA, so the rule of thumb goes...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 09-21-2009, 04:27 PM
jehardiman jehardiman is online now
Rep: 1623 Posts: 1,483
Some of the early all aluminum or aluminum and bronze boats were glued and riveted like aircraft. Because of the difficulty welding, a welded boat required a filler to make it smooth, glued and riveted construction did not and therefor produced a lighter construction. But the reasons for it went away decades ago.
Aircraft are still glued and riveted for the light weight and the ability to repair & remove panels for inspection.
Old 09-21-2009, 05:26 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1786 Posts: 2,984
For a 3 meter canoe, what thickness aluminum would you recommend?
crazy idea ? bernhardusa Boat Design 25 07-12-2009 08:29 PM
Crazy boatthing idea - I woun't do it... Knut Sand Open Discussion: All Things Boats & Boating 5 08-08-2008 02:22 AM
Am I crazy, a different idea to replace stringers, will this work? 65 'cuda Fiberglass and Composite Boat Building 12 03-13-2006 03:41 PM
crazy idea??? terabika Boatbuilding 3 09-26-2005 08:14 AM
crazy idea??? terabika Boat Design 14 08-24-2005 04:57 PM
