Old 08-10-2005, 10:47 PM
MorganFab MorganFab is offline
Rep: 10 Posts: 2
Cold Galvanize
Does anyone have a opinion about using a cold galvanize for primer on a mild steel hull?
Old 09-30-2005, 06:35 AM
JimCooper JimCooper is offline
Rep: 10 Posts: 81
Works well, but only above the waterline outside and everywhere else. Evertime I expose or clean a piece of my boat I paint it with a zinc rich primer before the epoxy. Kills the rusting dead, wish we'd had it years ago would have saved a lot of chipping.
Cheers
Jim
Old 09-30-2005, 10:17 AM
Rep: 10 Posts: 2
cold galvy..
Thanks for the info jim, i will put it to good use Alex......
Old 10-01-2005, 08:33 AM
tazmann tazmann is offline
Rep: 192 Posts: 217
cold galvanize
Hello Jim
Im building a steel sail boat and was considering cold galvanizing the whole thing inside and out before epoxy. Is there a problem doing it below the water line? I just started researching the idea and any info (pros-cons) would be appreciated.
Tom
Old 10-02-2005, 02:35 AM
Rep: 1623 Posts: 2,343
Zinc primer
Zinc rich primers are the next best thing to hot zinc spraying. They will protect the surface very well.
Submerged metals should not be coated with sacrificial primers since under continual immersion any breach in the outer paint system will lead to the outer layers of paint disbonding following the zinc depletion. Use external anodes instead.
In the submerged areas use a high build surface tolerant epoxy directly over the prepared steel. Topsides decks and all the interior hull will benefit greatly from a zinc rich primer.
Mike Johns.
My hands get cold Thunderhead19 Software 14 04-27-2005 04:38 PM
Cold Molding Advice stuart Wooden Boat Building and Restoration 17 01-16-2005 12:39 PM
Wood Cold Molded Epoxy/Composite Builders winap Wooden Boat Building and Restoration 6 07-23-2004 08:02 AM
Baby,it's cold outside riverboathank Open Discussion: All Things Boats & Boating 4 01-09-2004 01:59 PM
cold galvanized floors Boatbuilding 3 02-16-2003 04:31 PM
