| Cock Pit Drainage Having nearly finished my boat ( 53 ft) I realise that if my centre cock pit is swamped there is no where for the water to go. OK for the foot well, I have two 2" dia dains but looking at the overall cock pit that dosen't seem nearly eanough. Does anyone know how to calculate how much water goes through a 2 " hole under gravity. What is the maximum time you should be flooded for? I feel an idiot as I designed the cock pit so that the seat backs kept the water out in most weather but if I get really pooped then the water is stuck and only the duck boards in the entrance will keep the central pilot house dry, which won't be for very long!! |
| There are several rules for this, the volume of your cockpit may be more critical than the size of tha drains. See for example http://www.phrfchesbay.com/eastdscert.pdf : 6.23 Maximum cockpit volume below lowest coaming shall not exceed 9% of LWL x Max Beam x Freeboard aft. Cockpit sole shall be at least 2% of LOA above LWL. (Sailboats built before January 1980 shall not be required to retrofit provided that their maximum cockpit volume does not exceed 12% of LWL x Max Beam x Freeboard aft.) |
| Fill it with a hose , and time the drain. 5 min is barely acceptable and 3 min is lots better. Waves come more often than that, Some boats can drain aft with big scuppers similar to "racing" sailboats. 3 sq ft of scupper on either side would not be too big. FAST FRED |
| That's i nice practical approach Fred :-) |
| Centre Cockpit Drainage | Allan Jennings | Sailboats | 0 | 01-13-2006 03:07 AM |
| water drainage | MilitaryPopo | Powerboats | 4 | 01-11-2006 12:48 AM |
| Help : Water Drainage | MilitaryPopo | Fiberglass and Composite Boat Building | 3 | 01-10-2006 07:37 PM |
