Old 10-07-2010, 12:48 PM
zulpas zulpas is offline
Rep: 10 Posts: 5
Coating inside keel
Quoting from the designer notes " Internal voids (rudder, skeg, fairing piece) to be filled and drained with bitumastic paint."
I had some of the stuff they used for underground pipelines and brushed it on internal surface of keel plates to roughly the height of the ballast. Now I want to coat the areas above the ballast line up to the access plates. Common sense tell me to use bitumastic again, however, the quality product I used before is not available anymore. I can get a quart of asphalt primer in Home Depot which can be used for underground steel and concrete. There are corners where I can't get to even to power brush it. Or should I buy epoxy paint, whole gallon of it. The asphalt primer covers everything while even the low maintenance epoxy requires a bit better surface to realize the cost/quality advantage.
The keel is going to be closed with bolted access plates so the only moisture possible down there is condensation for which the bitumastic should be good enough. Perhaps I can fill the remaining void with expandable foam after the ballast is in. Now I am thinking, will the foam stick to it?
Old 10-07-2010, 07:18 PM
Rep: 3125 Posts: 9,399
It's important you check for compatibility with the next coating you apply. Bitumastic paint can come in a few different forms. The usual stuff is an asphalt base, but coal tar epoxy, polyurethane and acrylic bases also have worn the "bitumastic paint" label on the can. Find out what it was previously and use a similar or compatible coating as your project continues.
Old 10-08-2010, 11:47 AM
Rep: 1493 Posts: 7,447
Compatibility is the key. We have all made expensive mistakes. The worse thing is to have a sticky mess that is almost impossible to clean.
Cast iron keel coating? Sam III Fiberglass and Composite Boat Building 10 02-26-2010 09:52 AM
Inside Out Doug Lord Boatbuilding 21 12-14-2009 05:47 PM
I want my turnbuckles inside the boat! Omeron Sailboats 3 06-28-2007 07:10 AM
new way to light up the inside of your boat Packeteer Boat Design 14 08-13-2005 11:03 AM
glassing the inside of a keel box.... capt'n ron Wooden Boat Building and Restoration 0 08-08-2005 08:29 PM
