Old 12-31-2005, 11:59 PM
Rob88 Rob88 is offline
Cement ballast in an Alloy boat
Hi, looking at purchasing an alloy yacht.
I noticed that in a lazeratte compartment there had been some cement poured in (over the internal painted hull surface). This presumably had been for trimming purposes.
Is cement used in this way likely to be a corrosion issue?
Secondly, the hull has been fared using what looks like automotive body fuller. The faring appears in places to be up to 8mm thick. In one place where the hull has been bumped, the filler has fallen out.
Is faring Alloy hulls an accepted practice?
Thanks in advance
Old 01-01-2006, 05:03 AM
Rep: 756 Posts: 3,328
Yes BUT , its more common to paint under the fairing compound with a 2 part epoxy based paint and use epoxy fairing compound .
Auto stuff "Bondo" shrinks a lot, is brittle and not water proof.
FAST FRED
Old 01-01-2006, 01:19 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Fairing (other than cosmetic touch-ups) of metal boats a sure sign of poor workmanship.....
Wynand
A scatterling of Africa
Old 01-04-2006, 02:33 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
....Or a vain effort to make a vessel appear younger than her years. Kinda like my Nana and makeup.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 06:54 AM
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
help building boat for school freakdude208 Boat Design 10 12-20-2005 08:39 AM
:) wheelife adventure wheelife Wooden Boat Building and Restoration 0 12-02-2005 08:08 AM
Putting togather a boat need help gincrew Boat Design 3 11-11-2005 09:40 PM
