Old 05-22-2005, 12:26 AM
cyclops cyclops is offline
Rep: 24 Posts: 1,057
Thanks PSG-1. Everybody please remember. Reefs and rock shoals are death to all types of prop drives lower than the hull bottom. Sand and mud or muck bottoms will destroy all COMMON built jet drives and possibly you if you eject in a turn with a channel marker pole in front of you. Very shallow running is definately asking for it to happen. Go slow in shallow.
Old 05-22-2005, 12:46 AM
PSG-1. Chain couplings can run that fast. They are used in racing Hydros. A mini scatter shield is a very good idea for the rare times they let go completly because no one saw the first of the 3 links opening.
Old 05-22-2005, 06:39 PM
tom kane tom kane is offline
Rep: 51 Posts: 696
Sounds like you are doing well and I am looking forward to new pictures.have a look at new image in photo gallery,Aircraft Technology it may give you some ideas.
tomkane
Old 05-22-2005, 06:45 PM
Rep: 51 Posts: 696
Building an Aluma-jet
Awful things happen with jet units too running in shallows.a blown jet.
tomkane
Old 05-23-2005, 11:10 PM
Pdouda Pdouda is offline
Rep: 10 Posts: 2
Your boat is looking good. Mine is still in it's infancy. I just made the cut for the bottom intake. I am planing on using the fiberglass shell from the waverunner. I am currently refiberglassing the intake to make it square and flat. I am planning on welding in 1-1/2" aluminum angle around the cut out. Then epoxying the fiberglass intake onto the angle. With a good amount of bolts as well. Hopefully it will work. I was going to use foam tape to seal it off, but I think the epoxy will do better. I am going to use 3M DP-190. It says it is flexible, hopefully it will be able to handle the different expansions of the materials. Anyone have any thoughts on this?
I will need to post or email some pics.
I finally got my boat registered. Turns out it is a 1950 jon boat. Pretty old...
Old 05-25-2005, 10:40 PM
Rep: 51 Posts: 696
Building an Alumna-jet
A drive as in the image is great for shallow water,but with a smaller and more protection around the prop.In a flat bottom or pod or tunnel gives good steering and directional control.The outboard motor can be fitted on a swiveling mounting,air strut or spring loaded that lifts the motor straight up and down when going into shallows.The thrust of the propeller keeps the outboard against the back of the boat until the loss of thrust allows the outboard to swing back and up,and you can use an inboard/outboard the same way..the next best thing for shallow operation is a cushion craft or air boat,but they have drawbacks.Diagram is an indication only.
tomkane
Old 08-21-2007, 12:56 PM
astro150 astro150 is offline
Rep: 10 Posts: 2
building an aluma jet
after 2 years i finally finished my jet boat project. you can call it a vacume if you want . i challenge anyone to follow me with an outboard prop job. i can get on top in 6'' of water an run in 1.5-2''of water and it handles like a dream.
building-aluma-jet-08_14_07_1930.jpg  building-aluma-jet-08_14_07_1933.jpg  building-aluma-jet-08_14_07_1935.jpg
Old 08-22-2007, 10:13 PM
Rep: 51 Posts: 696
building an Aluma-jet
Looks like a great job to me,and nice to see a finished project on this web site.It looks like you are in for some fun.Congratulations....
tomkane
Old 08-23-2007, 07:35 AM
Rep: 10 Posts: 2
thanks tom.not meaning to brag but the boat has exceeded all my expectations. the river i built the boat to run in is all but dried up an i can navigate it without any problem.the stick steering works great along with a trigger style throttle.
Electric Jet Ski Conversion glines Propulsion 40 10-08-2009 02:57 AM
jet drive for small river fishing kenstl17 Propulsion 20 01-19-2009 10:41 PM
Cyclops - 1971 Sidewinder jet boat jetboatjill Open Discussion 1 04-18-2005 05:33 PM
enhanced jet steering, custom built,patented Jeff Walkowiak Marketplace 0 09-30-2004 08:44 AM
Water Jet on a sailboat? Polarity Boat Design 19 01-19-2004 06:51 PM
