Old 11-06-2009, 11:36 PM
Jackphilps Jackphilps is offline
Rep: 10 Posts: 8
bow thruster tubes?
Hello there, fitting bow thruster tubes 200mm dia, just intrested in ideas or the 'correct' way to fit them?
Old 11-07-2009, 12:51 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Athwartship at the bow...
Old 11-07-2009, 09:59 AM
Rep: 10 Posts: 8
oh sorry, bow
Old 11-07-2009, 10:11 AM
apex1
Originally Posted by Jackphilps View Post
oh sorry, bow
Ahh, ja.
This may become the most informative thread since the invention of foot powder.
We just must try hard enough.
Old 11-07-2009, 10:49 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Check this Vetus manual I've enclosed here. You should find the info you need. You can see some informative pics in this site:
http://www.cantierelatino.com/instal...a_di_prua.html
The site is in italian, but I think those pics are pretty clear even without translation.
Old 11-07-2009, 10:57 AM
Rep: 1493 Posts: 7,447
It depends on the hull design. Is it a displacement or planing hull, etc.
Old 11-09-2009, 12:12 PM
Rep: 1758 Posts: 1,561
I concur with this. You can easily double or triple the drag penalty of the tube by improper placement as well as give yourself a living nightmare of a structural problem. The best case would be to see if the hull designer/manufacturer had already done the work and has recomendations. 20cm is not a small tube to be putting in one of the most highly loaded areas of a vessels structure. Tabbing and reinforcement will be substantial on a glass boat and weld joint design critical to prevent cracking on a metal one.
Last edited by jehardiman : 11-09-2009 at 12:14 PM. Reason: metal for steel to pre-empt comments
Old 11-10-2009, 01:47 PM
Rep: 10 Posts: 8
tubes
Its an aluminium boat and it has double bow thrusters. i have dimentions and and the tubes ready, thats not the problem, just looking for advice into the correct way to fit the tubes, to get them installed as accurate as possible. If there is a method or procedure?
Old 11-10-2009, 02:08 PM
What type of boat, bow shape (V, spoon, or other), and speed? My gut feeling is to recommend a shell insert just to resolve weld and strength issues as well as improve thrust output. Depending on speed and slamming, just using a corner weld (C2v.2) for the tube/shell connection is not the best way.
Old 11-10-2009, 02:34 PM
Depending on shape and speed, a fairing may be adviseable.
Old 11-10-2009, 03:01 PM
Rep: 10 Posts: 8
What type of boat, bow shape (V, spoon, or other), and speed? My gut feeling is to recommend a shell insert just to resolve weld and strength issues as well as improve thrust output. Depending on speed and slamming, just using a corner weld (C2v.2) for the tube/shell connection is not the best way.??
v hull, the rest of the information is not needed. Everything else has been designed, shell insert allready in place, as is said i have dimentions, all i want to find out is how to cut the hole's for the tubes accuratly, so they sit level and paralell. Is there a tool i can use, is there a method ? sorry if im confusing people.
Old 11-10-2009, 03:02 PM
Rep: 10 Posts: 8
im looking for advice from a builder
Old 11-10-2009, 04:13 PM
apex1
Jack,
you would have had advice from a builder, if you would provide the info requested!
But when the "rest is not needed" to quote you, it will be hard to get what you look for!
Regards
Richard
boatbuilder
Old 11-10-2009, 04:28 PM
If you need instruction on how to cut a hole level and parallel, this job is way over your head.
Old 11-10-2009, 07:15 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
I saw a tip section in a magazine on how to cut the hole level and parallel.
It was surprisingly easy and obvious with little tools.
Every thing is easy if you know how to do it!!
Fairing is always advisable. Keeping the tube deep enough is important --I seem to remember 1 foot min ( I dont know where I got that from) but some power boats will be able to plane with it out of the water which would certainly give you peace of mind that it wasnt dragging you down.
I'm conviced an eskimo style upswept split bow acts like a bulbous bow, but Squidly-Diddly Boat Design 4 08-23-2009 06:08 PM
Bow thruster thru hull mydauphin Boat Design 2 05-13-2009 01:57 AM
Bow thruster for shallow waters? ted655 Boat Design 12 12-22-2007 06:09 AM
Planing bow hull and getting over the bow wave hump kach22i Boat Design 2 04-03-2007 03:51 PM
bow thruster sonny Powerboats 2 04-09-2004 11:32 AM
