| Bow Railing Vibration I am having a 32" aluminum mono hull built. The plans show the bow railing stopping at the front of the cabin, about 8' on both sides of the boat. I want to extend the rails an extra 8~9' to the back of the cabin but I have heard that these rails will vibrate and resonate into the cabin. This I'm am told will be quite loud. Is there any means to dampen this vibration so my friends and crew can stay in the cabin underway. Any help in solving this vibration would be greatly appreciated. |
| Usually it is a matter of using rubber pads and connectors to isolate the rail from the cabin. If you wanted to get technical; To reduce the amplitude and increase the frequency you could stiffen up the railing by using a larger section rail, if you had a decent CAD drawing of the rail the vibration could easily be analyzed with an FEA package. Clamping heavy objects on the rail can also damp the amplitude but I think I would go with the rubber mounts.
| railing removal | bertram28 | Fiberglass and Composite Boat Building | 0 | 10-18-2005 11:50 AM |
| sistering of the bow | craigt | Wooden Boat Building and Restoration | 1 | 07-17-2004 12:25 PM |
| Vibration problem canting keel | nico | Boat Design | 5 | 05-29-2004 12:00 AM |
| Propeller shaft bearings, whirling vibration | christos | Powerboats | 3 | 05-08-2004 08:42 PM |
| Prop shaft vibration | sailvayu | Boat Design | 0 | 02-21-2003 05:11 PM |
