Old 09-12-2007, 12:06 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Best fasteners for aluminium
I need to fasten some aluminium plates to wood dock piers. Under water.
Seems my 2 choises are galvinized or stainless bolts.
This is brackash water, not fresh. There is bound to be a corrosion issue, or electrolois. I'm open to advice.
This is a long term installation
Thanks,
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 09-12-2007, 04:36 PM
Previous Member
Rep: 0 Posts: 0
Stainless and aluminium will not work if the water conducts electricity.
You can place nylon bushings in the plate so the bolts are insulated. This will prevent electrolysis.
Not sure about the galvanised bolts. The galvanising will sacrifice and then the aluminium hole will erode I think.
If it is not a heavily loaded situation you could use nylon bolts.
You can also get aluminium bolts that might not have any electrolysis issues depending on alloys.
Rick W.
Old 09-21-2007, 07:09 PM
thudpucker's Avatar
thudpucker thudpucker is online now
Rep: 343 Posts: 724
How about Wooden pegs?
You'd need Cypress and taper it in a lathe.
For flashing around piers, you have to auger a hole for the Peg, and make the hole in the plate large enough not to interfere with the driving of the peg.
Cypress lasts just about forever uderwater.
Old 09-21-2007, 10:43 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Assuming a fairly clean, solid surface on the pier, how about a good layer of tar or similar gooey substance from the local hardware shop. It will have the added advantage of not leaving a small gap between the pier, thereby saving the inside face of the plate AND the pier from attack by sea or sea life. Saves drilling and all the associated drama as well, Just a thought
Old 09-22-2007, 09:59 AM
ted655's Avatar
Rep: 122 Posts: 641
Thanks.
There is no electric current involved
Old 09-22-2007, 11:21 PM
alaskatrawler alaskatrawler is offline
Rep: 44 Posts: 46
Use aluminum bolts. Why not??
Dan
Bedding Fasteners boatrat Wooden Boat Building and Restoration 3 04-12-2005 10:51 PM
Wood Fasteners. Kosmic Sheep Materials 5 03-12-2004 08:40 PM
Stainless Fasteners searace Marketplace 13 01-30-2004 08:22 AM
Fasteners Materials 1 01-24-2003 06:37 PM
Fasteners Boatbuilding 3 10-16-2002 02:23 PM
