Old 12-10-2004, 02:41 PM
Rep: 66 Posts: 640
Originally Posted by Peter Large
Another question. Using an automotive diesel with all parts inc. radiator, would it be possible to link the cooling to a pipe running under the steel hull this way to effect a heat exchange?
Due Norway next week DSV Pelican.
Best regards to all on water, Pete.
Pete,
For your first question; automotive diesel can be used, but look at some other threads about re-powering and you'd might make up your mind.
Second question; yes, to my opinion it's a good option. Make sure you keep it close to the keel, but with enough space all around to get ride of shells, use enough spacers to weld it to the hull and protect the end with a taper to protect for groundings.
Solved to rolling yet? Did you try the ballasting?
Dutch Peter
Old 12-12-2004, 06:12 PM
Rep: 1729 Posts: 2,462
You are better off welding steel channel to the inside of the hull for the heat exchanger rather than putting it outside which is a poor option.
Mike Johns.
Old 03-29-2005, 01:29 PM
Paul Browne Paul Browne is offline
Registered
Rep: 10 Posts: 31
ballasting lifeboat
You might try some sand bags. Best to have it in plastic bags instead of paper. Building supply stores often sell sand in 55 lb plastic bags, commonly for play sand for children's sand boxes. I have a 28 foot lifeboat that I initially ballasted with about 2000 lbs of sand bags. Made a huge difference to the stability of the boat. See
www.geocities.com/geezerboat
After that was successfull, I saved space by removing the sand and installing 3000 lbs of scrap steel, which worked even better. To prevent corrosion inside the bilge, it's best to keep a dry bilge by installing a mechanical shaft seal, instead of the usual stuffing box.
Cheers,
Paul Browne
Geezer Boatworks
Durable Steel Hulls Wynand N Metal Boat Building 11 01-27-2009 06:19 PM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 06:40 PM
sail area vs ballast Tohbi Sailboats 96 06-02-2006 05:23 AM
25' trailer sailer LP Sailboats 44 09-02-2005 08:24 PM
255' Three-Masted Steel Barkentine for sale Yachting Marketplace 0 02-09-2005 09:35 PM
