Old 05-03-2007, 12:32 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Originally Posted by lazeyjack View Post
lets just say we are both rght DEal?
Lets have one together
Wynand
A scatterling of Africa
Old 05-03-2007, 04:28 PM
lazeyjack
Originally Posted by Rusty Bucket View Post
Lazyjack, I really enjoyed your gallery, that's some pretty impressive work. I suppose that's how you get to be a senior member. I believe you got the answer right about the welding symbol, I'm not sure if there is one either, regards, rusty
thanks Rusty, you can post some good feed, make up for all those neg ones I get for slamming Bush) you have a steel boat right?
Windvang here is designing me a good easy build for my lazy days!! he is fast, and very good with CAD, and he wears clogs and has tulips for brekky
Old 05-06-2007, 05:02 PM
dick stave dick stave is offline
Rep: 12 Posts: 144
Dont forget to feather your start-stops. No one mentioned cold lap here. You gotta burn em in or your boat will sink...
Old 06-07-2007, 06:12 AM
COLD-EH''s Avatar
COLD-EH' COLD-EH' is offline
Rep: 10 Posts: 62
So 12' seam down the center of my hull, do I tack weld and jump around or start at one end and continue to the other? If I move around, what kind of distance between sections? Thanks!
Old 06-07-2007, 06:48 AM
lazeyjack
centreline,? you mean oh centreline bar or on a plate seam? just follow my drawing, tack along first and chip back your stops
maybe make a sketch post it on here, one of the other guys will pick it up, bedtime here
Old 06-09-2007, 12:40 AM
COLD-EH''s Avatar
Rep: 10 Posts: 62
This is just a little boat, not a ship like most of you guys build! 12 gauge steel or 2.7 mm Airboat. Flat bottom, 88" wide bottom, 96" topsides. 5'X12' sheets with a 105 degree break at 44" (hard chine) to form the back portion and front portion curving to 5' bow, Decked over. I figured I would pretty much tack it together like a stich and glue boat, add my stringers after however was considering using some 1" .065" square tube for 2 or 3 stringers so center one could be backing the two sheets. Sound feasable? I wanted to build a truss for two of them to the height of the deck to have a strong structure to mount the engine stand but I could put one down the center as well? I don't need to as I will certainly have other areas that won't have backing and myself and machine are certainly capable of the welding task, but just trying to get as much input before I strike an arc. Thanks! Bill
Well, took my first step DryFoot Education 1 01-11-2007 05:21 AM
Step 12... Sean Herron Boat Design 5 12-07-2005 03:41 AM
The first and bravest step! Jdaddy Powerboats 4 07-14-2004 10:21 AM
Step Hull Johannes Pinl Powerboats 0 03-04-2004 04:08 PM
Step placement Archive Boat Design 7 07-18-2001 07:14 PM
