Old 10-14-2007, 12:05 PM
Hotel Lima Hotel Lima is offline
Rep: 17 Posts: 52
Attaching a Steel to Aluminum
Hello again,
What is the best method of attaching a steel hull to an Aluminum superstructure? I understand that is this very tricky business.
Thanks,
Jake
Old 10-14-2007, 01:21 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
I have read somewhere of a strip you do it with - one side you weld the steel to and the other side the aluminum.....seriously
Wynand
A scatterling of Africa
Old 10-14-2007, 03:55 PM
Rep: 1729 Posts: 2,462
Wynand the manufacturing process is called explosive bonding.
All the strips I have seen have been stainless steel on one half and alloy on the other. The last time I looked here it had to be made to a minimum order and cost an arm and a leg. A neat solution though particulalrly for plating.
The less costly way is to gasket, fully isolate and bolt both framing and outer plating.
Mike Johns.
Old 10-14-2007, 07:46 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
Hotel Lima, on lage vessels an expansion joint or a few are also required & incorporate a simple bellows glued in for water integrity, I only know cause I glued some in on warships, as Mike says there was a gasket in the connection to deck upstand & thousands of bolts all with fibre washers & probably sleeves through the holes too.Gluing in the bellows was kinda awkward as the joints set inside the deck & house line & heaps of wedges & batens required to maintain contact while the adhesive set. All the best from Jeff.
Old 10-15-2007, 08:09 PM
Rep: 3125 Posts: 9,399
A DeltaStrip and DeltaCouple are Dupont products that are steel and aluminum strips, explosive bonded to an inert center section. Weld the steel to the steel and the aluminum to the aluminum. Another method would be weld stainless flanges to the mild steel and bolt the aluminum to this with an isolator.
Old 10-15-2007, 09:09 PM
SaltOntheBrain SaltOntheBrain is offline
Rep: 66 Posts: 80
I think I remember a product called Al-Clad. It was plate steel on one side, aluminum on the other. Make the whole deck under your superstructure out of it. I will post up if I can reach my old boss to ask for more info.
Lance
Old 10-18-2007, 07:07 PM
Rep: 501 Posts: 1,767
Dont complicate this. Build hull of Steel, superstructure in aluminum with base that bolts to hull with stainless steel 316 nuts and bolts. Oh, I forgot to mention isolate AL from Steel via a gasket of epoxy or polyurethane sealant as gasket. AL is not touching Steel. Paint aluminum structure to prevent any residual steel corrosion from jumping up to AL.
Old 10-19-2007, 04:30 PM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
We use Detacouple on the Moloka'i Strait motoryachts and it works like a charm. This technology has been around for over 30 years. Our builders buy it with A36 marine grade milde steel on one side, and 5083 or 5086 aluminum on the other side. The oustide surface is sealed with epoxy filler and paint to keep the marine environment away, and on the inside the surfaces are covered over with polyurethan foam. I have never heard of a Detacouple failing.
In Europe, the trade name is Tri-Clad.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 10-28-2007, 10:18 PM
Etec Etec is offline
Rep: 10 Posts: 6
yup...i've use triclad to built aluminum superstructure and steel deck.
Old 11-06-2007, 02:52 PM
mastcolin mastcolin is offline
Rep: 133 Posts: 100
Loads of superyachts are ally superstructure with triclad join to steel deck/hull. It's no big deal.
The easy option is the bonding option though for smaller jobs I imagine.
To continue another thread, go the whole hog and build your sundeck/bridgedeck/flybridge in composite and bond that to the ally...stick the teak to everything
Regards
Colin
Old 01-09-2008, 03:01 AM
sarikawong sarikawong is offline
Great thread!!!
And thanks for all your ideas.....
http://www.cpint.hk/projects.php
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 06:40 PM
Steel vs Aluminum SheetWise Materials 7 05-17-2006 05:57 AM
Source for Steel/Aluminum Handholds JPC Materials 0 11-29-2005 02:26 AM
Aluminum vs. Galvanized Steel WAHiggins Materials 6 06-02-2005 12:32 AM
Steel and Aluminum Boatbuilder, Pac.N.W. SolomonGrundy Metal Boat Building 1 03-21-2005 08:33 PM
