Old 01-10-2008, 04:31 PM
SteelTrawler SteelTrawler is offline
Rep: 30 Posts: 11
Articulating rudder
I have tried before and got no response so here I go go again. Does anyone out there have experience with articulating rudders on displacement boats. Are they worth the extra complexity, cost? I would appreciate any comments.
Custom Advantage Marine
http://customadvantagemarine.ca
Old 01-10-2008, 04:37 PM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,510
If you mean "trim-tabs" on the trailing edge of rudders? I recall something around the time of Bondy's challenges and eventual win of the America's cup.
The distant memory seems to recall something like the effort in trimming (an extra man) weren't sufficient to further develop/use - effect was similar to adjusting the trim on aircraft and to point higher or improve vmg to wind.
Old 01-10-2008, 05:44 PM
Rep: 30 Posts: 11
No, these are rudders with hinge that allows the rudder to bend in the direction the rudder is turned by a simple mechanism that can be seen at the following commercial links.
http://www.bayviewedisonindustries.c...ts/rudder.html
http://www.rudderpower.com/tech.html
Old 01-11-2008, 12:44 AM
Kay9 Kay9 is offline
1600T Master
Rep: 279 Posts: 616
Steel Trawler. If your having problems with slow speed turning. Then yes this will solve the problem. However lately I have had a lot of luck by simply adding a wedge to the end of the rudder.
K9
Do they exist? articulating paddle wheel justinDesign Propulsion 27 02-01-2009 08:31 PM
Articulating rudder SteelTrawler Marketplace 0 01-05-2008 07:35 AM
Outboard rudder vs. inboard rudder designdreamin Boat Design 0 06-27-2006 10:05 PM
Rudder Angle And Effective Size Of Rudder... saildog Sailboats 5 03-06-2006 03:34 PM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 03:36 PM
