Old 08-15-2009, 04:33 AM
lumpy bumpy lumpy bumpy is offline
Rep: -3 Posts: 37
arc strikes
Just wondering what you guys opinions are of them . Are they a major defect ? , how can they affect the parent metal ? , is their a repair procedure ?
Old 08-15-2009, 04:47 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
Well I hav'nt a clue what you are talking about.
To me an arc strike is when you accidentaly flash your live rod in front of your eyes resulting in arc eye.
Old 08-15-2009, 05:16 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,691
L.B'y
As i mentioned on a previous thread the repair for an arc strike is give as:
If you're building a boat to Class, ie using the standard IACS quality method, it is thus:
a) Remove the hardened zone by grinding
b) Weld over a short bead over 50mm on
the arc strike
From IACS no.47 Shipbuilding and Repair Quality Standard, Dec 2004.
Like all things related to fatigue, it is cumulative. One item by itself can often appear very benign, but in the wrong environment, fatigue, can become very problematic.
It also depends upon ones point of view too. Since a small crack to repair whilst not catastrophic and making headline news, does occur, and frequently. These cracks are more of an inconvenience than anything else. But, when the crack is near the waterline, or below it..the minor aspect pales into the huge costs to repair owing to the dry docking that is require for such a small minor crack!
Old 08-15-2009, 05:44 AM
Rep: -3 Posts: 37
Congrats Ad Hoc , looks like that sense of humour removal operation was a complete success.
Old 08-15-2009, 06:56 AM
Naval Architect
Must have had a lobotomy too, since i haven't a clue what you're on about.
Old 08-16-2009, 07:44 AM
Rep: 1623 Posts: 2,343
Count me in that lobotomy, I'm lost here too.
Mike Johns.
Old 08-16-2009, 08:02 AM
Frosty's Avatar
As I appear to be the only member with a google facility I took the time to take a look.
http://www.steelstructures.com/StlInspNews/NEWS arc strikes.htm
Hey thanks frosty --na its ok.
ha ha---- it dont work you will get a 404.
Old 08-16-2009, 08:38 AM
Naval Architect
Mike
Same here too (post #227):
Welding a steel hull
No tangible reply.
Hence, can only assume that LB'y is not welding steel hulls to any Class
Old 08-17-2009, 03:30 PM
Rep: -3 Posts: 37
I thought surely someone could see the sarcasm in a thread entitled " arc strikes" giving the on going debate and input from yourselves on this matter in another thread . Perhaps British humour does not travel .
Surely you mean procedure not class adhoc ?
Old 08-17-2009, 03:41 PM
apex1
l b
you know you´re actually fighting with a "Brit" ???
Old 08-17-2009, 06:46 PM
Naval Architect
L,B'y
As i write this, can you tell if i am smiling or laughing or grimacing???..surely someone can see???
As for procedure not Class, again, vague, why is that..or must i guess since surely someone must know?
If you are building to Class, everything is about correct procedure and QA, your question is about procedure, so that is what the reply is referring to, unless you're reading something into my reply there that is not there. Surely I'm being sarcastic in my reply and don't know about it!.
Ergo, if you do not or are not aware of this formal procedure for 'arc strikes', then you cannot be building steel boats to Class.
Old 10-25-2009, 05:37 PM
Rep: 1397 Posts: 7,215
I think the rule is three strikes and you're out
Old 10-26-2009, 02:30 AM
Rep: 418 Posts: 777
4 balls and you walk!
Old 11-20-2009, 03:23 PM
Member
Rep: -33 Posts: 951
Not worth worrying about
Old 11-20-2009, 07:45 PM
welder/fitter welder/fitter is offline
Rep: 423 Posts: 407
Yeah, Lumpy, I recognized your post as feeding the fire, hence, no response. have a nice day! LOL you trouble-maker, you!
Can a boat be grounded for lightning strikes? justinDesign Boat Design 2 01-18-2008 06:36 PM
finding the arc between two points Mcgyver Boat Design 16 09-18-2007 09:38 AM
Asking Opinion & Comment in Learning Naval Arc. Syukri Open Discussion: All Things Boats & Boating 0 03-22-2007 12:16 AM
lightning strikes on steel boats? fulkne12 Boat Design 11 05-22-2006 02:20 AM
ARC Marine Everyman martin Pedel Wooden Boat Building and Restoration 2 08-16-2004 06:35 PM
