Old 04-15-2006, 05:17 PM
globaldude globaldude is offline
court jester
Rep: 10 Posts: 110
Any tecnical problems joining m/s with cor-ten ?
Ahoy you teco engineering types, any problem with you're aware of, joining, say cor-ten decks to mild steel hull ?? , electrolisis ? --- I think I'll post this ? elsewhere as well to get an answer. I'm about to build new decks on an exsisting mild steel hull .
I seem to recall reading in a Bruce Roberts catalog I once purchaced, that he [ they ? ] was not in favour of useing any steel other than Mild steel for construction. Why ?, I don't know, which is why I'm asking you lot !! ?.
Seems to me, especially on the decks where you're likely to drop something & chip the paint, that 3mm cor-ten would have a strength & anti corosive benifit.
If money were no problem, I'd go for stainless decks & cabins, as has a friend of mine on his 82' ketch [ it's finished - awesome - twin gardners - powered everything - powerfull rig & sails well !! ]
Pete.
Old 04-16-2006, 08:19 AM
Rep: 1623 Posts: 2,344
Pete
You can use any standard mild steel welding technique to join the two.
For future ref joining mild and stainless needs welding with stainless wire/rod.
You are confusing electrolysis with galvanic corrosion above.
Higher carbon steels can have their problems, but for your deck its a good idea to save weight, corrosion reduction is not that significant. Aluminium can be used for the deck and superstructure of a steel hulled boat too. Needs gasketing but is easy enough to do, else you can buy a bonding strip with steel on one side and Al on the other.
I haven't seen a full stainless deck yet but it is certainly possible. Modern modified epoxy paints are incredibly tough and are making mild steel a very durable material in a marine environment.
I hope this gives you some hints
Mike Johns.
Old 04-26-2006, 06:28 AM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
Cor Ten required low hydrogen consumables.
omc problems double00 Propulsion 9 08-07-2006 09:27 AM
Joining longitudinals to the frames KajWestergard Metal Boat Building 40 02-14-2006 04:03 PM
Joining longitudinals to the frames KajWestergard Boat Design 0 01-24-2006 02:52 PM
Engine Problems aznewsh Propulsion 2 07-26-2005 09:15 PM
Joining points in Prosurf Willallison Software 2 09-09-2002 06:49 PM
