Old 01-26-2006, 06:49 AM
LOHI LOHI is offline
Rep: 10 Posts: 3
Anti fouling
If I put anti fouling on my aluminum hull boat, and a small area is left exposed or wears thru, will that area corrode at a rapid rate?
Old 01-26-2006, 02:18 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Why would you want to? leave a bit unpainted I mean!
If your going to leave a bit unpainted why bother to paint at all? Save some money, don't paint! OK you'll go pretty damn slow with all the s*** on the bottom but maybe you like going slowly!
If however a bit chips off which is what your really worried about I wouldn't panic, get it done as and when - sooner rather than later but I certainly wouldn't panic!
Now if I had a great big bit of copper hanging down and no anodes then I would panic, but paint, naw
Old 01-29-2006, 04:30 AM
mastcolin mastcolin is offline
Rep: 96 Posts: 89
You should put primer on the hull 1st. I wouldn't suggest putting the af on direct. Once you've primed, that stops the corrision on the alloy. The af just helps keep the green off.
Make sure the af is alloy compatible. Pure copper oxide ones will eat holes if you scratch through.
Old 02-05-2006, 10:17 PM
Rep: 1623 Posts: 2,343
To do a proper job on an immersed Al hull; You should paint the underwater part of the hull with at least two coats of epoxy extending well above the waterline. Then anti-foul. You will also need anodes.
Mike Johns.
Anti-thft device for boats Landokia Marketplace 7 05-14-2008 01:32 AM
Anti slip in mold? Splint Fiberglass and Composite Boat Building 3 04-25-2005 12:15 PM
anti-skid deck texture Lew Morris Materials 21 07-14-2004 02:30 PM
Anti Rolling Gyros ivansalasj Boat Design 0 05-28-2004 06:33 PM
anti-skid deck texture Lew Morris Boatbuilding 4 08-02-2001 06:02 AM
