Old 07-20-2010, 07:02 AM
Lexluthor Lexluthor is offline
Rep: 10 Posts: 13
Anodes, welding or screw
Hi all,
On a steel hull replacing the anodes, what's your opinion should you weld the anodes directly on the hull or weld on some threaded rod (galvanised steel or stainless? what about electrolyses dissimilar metals?) and screw the anodes on?
I'm concerned about welding them on, sure you can cover the welding strips with primer and antifouling but sure enough water can get behind the strips, the weld itself and some of the metal is blank metal so it's totally unprotected from paint.
Old 07-20-2010, 09:46 AM
Rep: 1758 Posts: 1,561
Read my response here:
welding zinc divers delight
Old 07-20-2010, 09:53 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Welding is no option here. The anodes have an embedded steel strip with mounting holes. Use stainless bolts and nuts, so you can replace the anodes without difficulty after a couple of years.
Do not worry about electrolysis, that is what the electrodes are there for.
Old 07-21-2010, 05:03 AM
Rep: 10 Posts: 13
thank you very much for the info guys
Anodes dick Boatbuilding 2 08-21-2009 06:35 AM
Replacing anodes - too many ? Dave-Fethiye Wooden Boat Building and Restoration 1 06-19-2007 05:49 AM
Sacraficial anodes martinwill DIY Marinizing 2 05-14-2007 09:57 AM
Displacement hulls, twin screw more econimical than twin screw? JohnJewel Propulsion 11 01-08-2006 11:40 PM
Anodes sailrjim Metal Boat Building 9 12-04-2005 04:48 PM
