Old 01-16-2012, 06:29 PM
rendon_6 rendon_6 is offline
Rep: 10 Posts: 3
Am I crazy? Extending boat's length
Has anyone ever cut the back end off their boat and added a couple feet in than welded it back together? Or would that be to crazy. I have a 12 ft flat bottom and I wanna 16 ft. So I would have to add 4 foot in and than i would want to add pods to the back.
What do you all think or am I just crazy?
Here it is now
Here is what i am thinking
Plan A
I would remove the back seat and cut off the last 1 1/2" to 2" than weld than weld the 4 foot section in, add a few supports and re install the seat in.
Plan B
would be to cut the the boat about 4 foot from the back just in front of the rear seat than weld the section in and add supports.
Would I have to put the square chimes in the bottom of the piece that i added in on both plans i thought i might be able to get away from the chimes if i did plan a and just had the last 4 foot smooth.
than i would add a deck to the front with a door to store things in and pods to the back.
What you all think
Old 01-16-2012, 07:45 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Been there done that with a glass boat a few times
We are all a little crazy !! hardest part id finding the right place to chop it !! Added a metre into the last boat i cut and made it into a really nice boat . was a short fat thing and a terrible sea boat!! Uncomfortable to ride in !bounced around and flopped in a harbour chop .The guy bust wanted a couple of feet but talked him into a metre and changed the motor from a really old omc 85hp to a brand new 90 merc lighter motor , more power and the extra length change the whole thing . more room inside , no more buncing from one chop to the next , and flop went completely !
An Aluminium boat shouldnt be a issue !just make sure you cut it nicely and straight lap the joins rear inside each join . Riviting or welding the 2 joins ?? string line the keel and make sure you get the line 100% straight when you join it again . The hardest thing is doing the first cut !,Is all done in minutes and you wonder what all the fuss was about .
Plan B would be my option and make the cut half way between the frames so have room to work and be sure . Have you talked with the boat manufacturer and see if you could get a section of the hull pressing with all the shapes in it already or even find a damaged boat the same sort and hull shape
Me being a glass person i would make a mould off the existing hull and make a glass section witha flange each end then rivit and use West flexable Epoxy the joins with 30 mm over lap each way !
Making beautiful boats is a passion never a chore !
Old 01-16-2012, 08:54 PM
Rep: 1493 Posts: 7,447
They extend ships, so no, you are not crazy.
Old 01-18-2012, 10:56 PM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
Frankly I would just buy a bigger boat.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 01-18-2012, 11:21 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
I'd like to extend most of the boats I own. Two of the Alaska State ferries got extended many years ago and 100% successful as far as I know.
Easy Rider
Old 01-19-2012, 06:12 AM
Rep: 670 Posts: 2,457
Before you chop and stretch your jon boat, MAKE SURE THAT YOUR RIG WILL FIT YOUR CAR
Very very important.
Old 02-09-2012, 09:55 PM
old one !
That picture made my day !! Fantastic !!well done !
Old 02-13-2012, 07:42 PM
cor cor is offline
Rep: 85 Posts: 94
I extended this one from 18' to 22'.
It is a lot better boat now.
C.O.
http://whatsintheshop.blogspot.com/
Old 02-15-2012, 09:53 AM
johneck's Avatar
johneck johneck is offline
non impediti ratione cogi
Rep: 74 Posts: 66
Sounds crazy to me. While completely possible, the benefit is probably not worth the effort. They make these alum boats in many sizes and shapes; buy one the right size.
Old 04-17-2012, 09:45 AM
The Loftsman's Avatar
The Loftsman The Loftsman is offline
The Loftsman
Rep: 41 Posts: 57
Yes you can but be careful and extend it amidships for'd and aft perhaps a frame space or so each side of midships, there have been disasters at sea put down to this not being done correctly and has cost life.
Cheers
"Fairline" A line that is pleasing to the eye!
www.leithshipyards.com
http://leithbuiltships.blogspot.co.uk
Changing a boat's characteristics Strudders Stability 15 11-02-2010 01:30 PM
How to estimate a boat's weight ? Trevano Boat Design 6 08-25-2008 12:33 PM
Newby replacing aluminum boat's floor Brylk1830 Materials 12 05-27-2008 09:28 PM
Help extending? Matt.D Boatbuilding 47 12-14-2007 09:22 AM
finding boat's resistance plain_sailing Boat Design 3 10-11-2004 02:47 AM
