Old 05-05-2009, 08:18 PM
Daniel Lance Daniel Lance is offline
Rep: 10 Posts: 3
Aluminum sheet and plate in metric sizes
Does anyone know of any Aluminum Suppliers in eastern Canada that stock marine grade ( 5086 or 5083 ) sheet and plate ? All the Suppliers I have contacted in the eastern and southern U.S. do not .
Old 05-05-2009, 10:52 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Hi Daniel,
Is there a particular reason you must have metric-dimensioned plate?
I cannot think of many situations where it would be particularly problematic to substitute an inch-dimensioned plate of very nearly the same thickness. For instance, 1/4" plate ought to be an OK substitute for 6mm in most applications, since it is only 0.014" thicker than 6mm plate.
Old 05-06-2009, 08:21 PM
Rep: 10 Posts: 3
Matt,
Thanks for the reply. I bought a set of plans from Mike Waller of Queensland Australia for a 13m Aluminum Powercat. The boat is designed using metric thickness sheet, plates angle flat bar and square tube. Bare weight of just the hull is around 6526Kg. It is my belief that deviating from "as designed" could incur a weight penalty at best and possible structural deficiencies at worst. I really need to achieve the performance the architect intended.
Daniel
Old 05-06-2009, 10:22 PM
Luckless Luckless is offline
Rep: 105 Posts: 162
Contact the architect and talk to them about it. Often sheet metal is produced with a fairly large variance from the stated thickness, so talk to the architect about the impact it will have.
At the very least any decent sized metal yard should be able to hook you up if you're willing to pay a little extra to get stuff they don't normally stock.
Old 05-10-2009, 06:14 PM
Rep: 10 Posts: 3
Matt and Luckless,
Thank you both for the advice. I will contact the architect and ask his opinion. It is my desire to do the best job possible when constructing my boat and not do anything I will regret later.
Old 08-21-2009, 10:24 PM
Clifford Barney Clifford Barney is offline
I have a large quantity (10 tons) of aluminum 5086 from a U.S. Navy warship in Louisiana. I don't know the thickness yet, but we're scheduled to begin breaking it up next week. There is the potential for cut-to-spec for DIY boat builders. Contact me if interested.
Old 08-21-2009, 11:13 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
there will be almost no weight addition at all, your 5/32 is almost same as our 4mm, yout 3/16 a touch thinner than our 5, your 1/4 is 6.25mm and so on, one inch is 25.4m, you can work it from there
in other words, 5/32 is 3.9 mm, ten thou under
you are better with 1/8th than 3mm. it is .125 inch thicker and will work with less distortion
Aluminum 5086 or 5052 plate? DanAyo Materials 7 01-24-2009 07:07 AM
wanted: sheet aluminum pabble Materials 6 08-13-2007 11:42 PM
wanted: 5052 aluminum sheet .25" pabble Marketplace 0 06-14-2007 10:59 AM
Aluminum sheet on ply bottom? gwaa98 Materials 2 02-20-2006 06:54 PM
MIG welding .080 5052 aluminum sheet Jack D Davis Metal Boat Building 2 09-26-2005 10:07 PM
