Old 04-01-2006, 03:53 PM
jmac jmac is offline
Rep: 10 Posts: 27
Aluminum Mig Wire
I will be welding 5083 aluminum plate soon. My supplier says he stocks 5356 for the local builders. He says 5183 is better but doesn't stock it. Why are the builders using the 2nd choice material?
Old 04-03-2006, 12:34 PM
antonfourie antonfourie is offline
Rep: 13 Posts: 169
I can think of two reasons
1. Cost
2. 5356 could be better for welding different grades together, whereas 5183 may only be for welding 5083 to 5083
Old 04-03-2006, 08:23 PM
SeaQuiCk's Avatar
SeaQuiCk SeaQuiCk is offline
Rep: 10 Posts: 3
I don't think the cost is the reason, both filler wires are simmilar in cost.
Take a look at the attached files and decide for yourself, both options are valid, but 5183 is the better choice.
Greetz,
Jerry
The only way to cross the river, is to cross it...
Old 04-03-2006, 09:55 PM
Rep: 10 Posts: 27
SQ
I looked at what you sent. Can you sum it up for me. Im not that technical.
Thanks.
Old 04-04-2006, 06:06 AM
Rep: 10 Posts: 27
After further review I get it now.
Old 04-04-2006, 08:49 AM
Rep: 13 Posts: 169
Still strange that they don't stock 5183 then.
Old 06-06-2006, 10:42 AM
stonebreaker stonebreaker is offline
Rep: 42 Posts: 438
This is just a guess, but perhaps the 5356 wire feeds better (is stiffer) than the 5183? Maybe you don't need a spool gun if you use a teflon liner and correct drive rolls?
Anyway, this page might interest you: http://www.alcotec.com/techpage.htm
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
Old 06-06-2006, 10:55 AM
Rep: 10 Posts: 27
Seems the CWB in Canada doesn't approve 5183 filler material.
Old 06-06-2006, 12:27 PM
Rep: 42 Posts: 438
Well, that would explain it then...
Stonebreaker
TIG or MIG for Aluminium? ted655 Metal Boat Building 16 01-22-2006 01:58 AM
MIG welding .080 5052 aluminum sheet Jack D Davis Metal Boat Building 2 09-26-2005 10:07 PM
mig rico Marketplace 0 04-30-2005 03:01 AM
First time MIG user captain butch Materials 1 10-14-2004 01:00 PM
Welding Wire Arrowmarine Metal Boat Building 2 09-03-2004 02:01 AM
