| aluminum bonding for sailboat I am considering a sailboat selfbuilt out of aluminum, most likely a multihull. FYI I havent found a plan yet but am looking at 36-42'. My immediate barrier is the ability to execute a selfbuild with my current resources. I don't really have an absolute preference for which material I use (no steel) I only need to be able to get the hull(s) done and floating quickly ( months not years)so I don't burn my cash on a storage/buildsite . After that I have a water site to build it out. Aluminum seems cost effective, fast and durable if I don't have to hire out the welding. A friend who builds light aircraft suggested aluminum over , ply epoxy laminate, grp , cold mold etc.. saying the aircraft industry has been "gluing "aluminum for years. I have read most of the sites and threads here and I know it can be done but I havent read yet where someone said " Yep I did it and she came out fine". If your out there speak up. Point of reference... I bonded an aluminum plate 1/4" x 12" x 12" to the fiberglass hull of my boat to create an area for outboard motor mount. Since I thru-bolted it anyway and I was mainly concerned with a strong watertight seal I used a tube of 5200 I had laying around . There was minimal sanding on the glass and a quick hand cleaning with acetone and no prep at all on the aluminum plate. I do not know if it was coated or not but it did not appear so. It looked new and shiny and I could not say what type of plate it was as it had been given to me for this purpose several months before. It has been there nearly 5 years on a boat floating all day every day in salt water . Last year I attempted to dismount it to relocate it .. MEBS! I pried, pushed, drilled a "grab hole" for a large bolt, hammered it a bit ...no good!! I dont have any way to measure "shear", "peel" or any other fancy term for failure but I can say that suckers on there short of cutting the entire section out and doing a repair. BTW I hung a 90lb 2stroke Johnson on it so it definitely got some vibration and flex. Goodluck to all SAM |
| Duplicate post, also found in this thread which has a lot of data on Aly bonding. Bonding Aluminum with Epoxy
| Hi friends. This is very beautiful and also strong of aluminium bonding on a sailboat you should be do this by a good worker he will be bonding your boat of aluminium. Thanks.
__________________ Shop fronts London |
| Bonding Aluminum with Epoxy | Chris Krumm | Materials | 49 | 02-10-2012 04:16 AM |
| aluminum and epoxy bonding | geoshep | Boat Design | 11 | 01-01-2012 06:21 PM |
| Bonding Aluminum/Gelcoat and Perfection | missinginaction | Fiberglass and Composite Boat Building | 8 | 03-04-2011 09:15 AM |
| cost to build a little aluminum sailboat | Jehu | Sailboats | 9 | 12-28-2006 09:53 AM |
| Looking for Boatbuilder for aluminum sailboat - Canada | Erik | Services & Employment | 15 | 02-16-2005 09:38 AM |
